Page 2 of 19 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 183
  1. #11
    VXR Nothing comes close wayne/VXR's Avatar
    3rd February 2008
    23,569
    Please adhere to the following advisories to achieve maximum life and performance from your turbo vehicle.
    1. We strongly advise using Optimax or other high quality, high octane fuel.
    2. Please do not use full boost under 70 degrees water temp.
    3. Please do not use full boost over 95 degrees water temp.
    4. Use Milers Octane Plus or CVL, when good quality fuel is not available.
    5. Reduce your performance to low boost on low fuel or under ¼ tank, this can, in extreeme cases cause air to enter the fuel system
    6. Run the car for 2 minutes after high performance use
    7. As soon as the oil turns black we advise changing.
  2. #12
    VXR Nothing comes close Tom_Y2K4's Avatar
    3rd August 2009
    24,529
    Quote Originally Posted by Thorpy View Post
    1. Always let it warm up before giving it some beans
    This can be monitored through the secret screen. Once the water temperature hits 95, wait a further 10 minutes before going full boost. This is to ensure that the oil temperature of booth the engine and turbo are up to temperature to prevent damage to parts.
    The guideline 10 minutes may be longer in the winter due to cold conditions.
    Leaving the car on idle does not count as warming up and should not be carried out unless waiting for the windscreen to de-mist as it can cause damage to the engine over time
    link to the guide on how they can access the secret screen?
    Added mate Cheers.
    South East Regional Organiser
    PSN: TomFL12
  3. #13
    3rd August 2009
    24,529
    Quote Originally Posted by wayne/vxr View Post
    Where is that a copy paste from mate?
    PSN: TomFL12
  4. #14
    Saphire black bunny - check out my mirror finish reflections
    7th November 2009
    177
    Good Post mate!
  5. #15
    Are you VXR enough?
    30th March 2009
    914
    Good posts guys!
  6. #16
    3rd August 2009
    24,529
    Added where relevant, cheers fella
    Can you please advise on Regal Warranty?
    PSN: TomFL12
  7. #17
    3rd February 2008
    23,569
    a good post mate,lets try and help corsa vxr owners.
  8. #18
    3rd August 2009
    24,529
    Cheers Kinda stole Stewart's idea from your thread but all the same....
    It might result in a drop in posts but if it gets used then it has a purpose. I think its important not to re-invent the wheel, the majority of items have been covered 100's of times so referencing back to search is crucial.
    Any further input from yourself or knowledgable others greatly appreciated.
    PSN: TomFL12
  9. #19
    VXR enough jps's Avatar
    23rd April 2010
    1,779
    Brill post nice one! The one stop shop for newbies
  10. #20
    3rd August 2009
    24,529
    updated with 10. Servicing + Warranty
    PSN: TomFL12
