Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 53
Thread: Stage 3 EDS
    24th August 2010
    121
    Default Stage 3 EDS
    What diffrent maps from EDS are there for stage 3 and has any1 gone any of them on here and what bhp are they cuming at
    VXR enough Nurburg608's Avatar
    13th March 2009
    2,830
    What suporting mods do you have as that will define what map to use
    24th August 2010
    121
    Scorpion 3"exhaust and tx autosport fmic with all the pipes with the replacement tophat and the cdti airbox
    13th March 2009
    2,830
    I'd look at the 315 map for that setup. Pretty similar to what I was running on that one.
    24th August 2010
    121
    Cool cheers bud what bhp was your doing then,and what's the 1just up from the 315ps 1 wud I not beable 2get away with that 1
    13th March 2009
    2,830
    Just under 300bhp, but plenty of others running that map with higher figures than mine
    The 285 map is pretty much the same. With the 315 your meant to have the cam but again others have run it without it with no issues.
    The next map up requires the EDS inlet manifold from memory.
    Weaving life's Rich Tapestry...
    14th September 2009
    5,751
    Quote Originally Posted by Nurburg608 View Post
    Hmm i was looking at the 330ps map next week when i fit a hybrid. But i dont have the inlet manifold, although Ian at mpg said it would be ok to run that.
    13th March 2009
    2,830
    Quote Originally Posted by Dab vxr View Post
    3 bar map sensor?
    VXRed blooded Roger_NL's Avatar
    20th May 2009
    352
    i have 316hp and 492nm. But i also have the inlet cam of EDS.
    14th September 2009
    5,751
    3 bar map sensor?
    No i dont. I was under the impression it wasnt needed either
