Results 1 to 10 of 11
    The dancing Stormtrooper
    26th May 2009
    1,982
    Thumbs up 1.9 filter change
    I am going to be servicing the car soon but don't no how long the life of the 1.9 kit filter is? Any ideas? Also I went back to vx spark plugs as the other ones caused problems, they have been in about 5k should I change them as well?
    Thanks in advanced
    I wanted a yellow tint, not a perm! - Moderator vxrdave's Avatar
    18th April 2006
    15,993
    I have a brand new 1.9cdti vauxhall filter sat in my garage if you want one, think its every 2 years its changed.
    26th May 2009
    1,982
    pm'd, any info on the life of gm spark plugs?
    Santa and Spinach...
    5th June 2009
    6,514
    If your tuned id change the plugs every 10-15k i do to be on the safe side.
    18th April 2006
    15,993
    Vauxhall say 4 years or 40,000 miles but as beefy says worth doing it early.
    5th June 2009
    6,514
    Mine where cooked after 10k and you can find it messes with your boost levels.
    26th May 2009
    1,982
    Think I will change them as well then, thanks for the info.
    VXR's cold storage monster Red Ice VXR's Avatar
    13th August 2006
    4,583
    Is it hard to change spark plugs? Or is it just 1 out 1 in?
    Arden Blue Astra , 19's, Bluetooth, Full Leather, Stage 2 Ready
    Wanted: 18" Black Wheels, maybe an FMIC and Stage 2
    5th June 2009
    6,514
    Yeah easy enough, but you need the correct tools, and make sure engine is cool.
    25th May 2010
    337
    And careful not to cross thread them. The spark plug should be softer than the female thread so if you do balls it up the plug thread dies and not your engine's but better to be extra careful
