Results 1 to 9 of 9
    The dancing Stormtrooper BIG J's Avatar
    26th May 2009
    1,982
    Question Gearbox Oil Change
    How often should the gearbox oil be changed? I have always wondered
    And what is recommended? Cheers
    Astra 320 (Top Secret Spec ) I'm so JDM I don't have to drive one
    VXR FOR SALE: http://www.vxronline.co.uk/forum/sho...vxr-Arden-blue
    Are you VXR enough?
    27th September 2010
    860
    can this be done? i was told you couldnt
    VXR Nothing comes close worky's Avatar
    4th April 2009
    19,466
    Quote Originally Posted by HSVXR View Post
    Can indeed be changed.
    | Find | Watch | Follow |
    6th February 2008
    15,843
    The gearbox oil is classified as a non serviceable item so it not changed on the service schedule.
    It does not stop you doing it yourself.
    26th May 2009
    1,982
    Quote Originally Posted by worky View Post
    Any recommendations on oil?
    VXRed blooded gman's Avatar
    21st July 2008
    298
    Royal Purple or Amsoil are the only oils I use for both gearbox and engines.
    Changed over after I lost an expensive race engine to a reputable oil brand years ago.
    Neither have ever failed me and the race engines (as well as daily drivers) have never looked on rebuilding or performed better.
    Astra Mk4 SRi-T
    Cosworth pistons, Pauter Rods, EFR turbo, 2200cc injectors fueled by E85
    526hp @ flywheel (30psi)
    27th January 2011
    264
    Quote Originally Posted by gman View Post
    its funny you said that gman, someone mention this oil to me a few weeks ago and how good it was. Where do you actually get this from though? which shops
    VXRacing ahead Bawb's Avatar
    3rd December 2009
    687
    fancy putting some links up mate for us lazy people
    Arden VXR, 19" Anthrecite alloys, TMS Stage 3, Forge FMIC, Remus, K&N Panel filter, Insignia washer jets, RARB, DAP's, Sight and light, Keyless, Forge recirc valve, Percys oil restrictor and breather box, 3 Gauge conversion, VXR front grille badge, VXRonline window stickers and The Origional Percys Airbox
    21st July 2008
    298
    Sorry guys, been away with work.
    As i live in Australia where I buy it from prob wouldn't help you much.
    What you're looking for is a 75W90 gearbox oil from either RP or Amsoil.
    The RP is Syncromax, the Amsoil is the Severe Gear oil.
    See if there are any UK distributers or if worse comes to worse get it from US eBay (which is where I used to have to get mine from).
    Also the RP and Amsoil engine oils are, IMHO, the best out there as well.
    RP XPR or Amsoil Dominator series oils are the way to go.
    Astra Mk4 SRi-T
