Results 1 to 10 of 19
    You only get a arrrrrr with VXR rosco.p's Avatar
    30th August 2009
    10,442
    Default HOW TO - Fit Lowering Springs
    Front
    1. Jack up car and put on axle stands
    2. remove wheels
    3. remove 3 bolts in strut (2 lower ones that hold the hub onto the strut and the other top one holds the plastic arm onto the strut. you cant see the lowest bolt in the pic)
    4. remove the wires and brake hose from strut ( plastic clip)
    5. push the hub down so the strut is now hanging free.
    6. under the bonnet remove the plastic clips holding the strut in place (best get a hand from someone to hold it while you remove the clips or the strut will just fall out)
    The clip splits in half, use a screw driver to prize apart, be careful not to damage it.
    7. remove strut from car
    8. use a spring tensioner tool to clamp the old spring
    9. with the spring fully compressed remove the top nut on the strut, this is the hardest part as 9 times out of ten the nut is corroded on!!! you need to soak in wd40 and use a goose neck ring spanner to get a good fit on the nut and hold the center of the strut with a torx bit. (best to slacken it while the car is still on the ground)
    (another idea is to nip down to your local garage or kwit-fit etc with the struts and get them to remove the old springs and fit the new ones if you don't have the tools)
    10. lay out the parts as they come off so you know which way they go back on!
    11. slacken the spring clamps off the old spring and fit to the new spring and compress it.
    12. fit your new spring and make sure its sitting in correctly, you will see a seat for the spring to sit in (look to see if there are marking to say which way is up as some springs have a top and bottom)
    13. refit all parts to the strut, once tight release the spring clamps.
    14. refit strut to the car and fit all nuts and bolts and wires etc.
    15. make sure all parts are tight and fit wheel and lower car back to ground.
    Job Done ! now for the other side
    Rears are very simple
    1. Jack up the car and place on axle stands (at the rear axle mount will be fine)
    2. Remove Wheels
    3. Jack up the rear axle just to take the weight slightly
    4. Remove the bottom bolt from the rear strut on both sides
    5. Lower the jack to lower the rear axle (a little wiggle and poke here to get the axle free)
    6. The springs will now just fall out
    7. Remove the rubber cups and inspect for wear or damage, fit to new springs if ok
    8. Fit the springs to the car using the steps above in reverse
    9. Refit wheels and lower car to the ground, job done
    Hope that helps you, any questions feel free to ask!
    Arden Blue // Aero Pack // Blue Nappa leather Seats // Dual Zone Climate Control // Navi 600 // Rear Tints // Electric Folding Mirrors // Tire Pressure Monitoring System // Premium Lighting Pack // Rear Parking Sensors // Driving Assistance Pack
    1st May 2010
    1,511
    Thanks for this. Sorry if it's a daft question, but when the rear is up on axle stands, what is the purpose of then raising the axle (point 3)?
    Harry
    | Adjustable RARB | Breather Box | Insignia Washer Jets | Oil Restrictor Bolt | Cobra 2.75" Decat Downpipe |
    30th August 2009
    10,442
    Quote Originally Posted by Amraam View Post
    So when you take the bottom bolts out the struts the axle don't shot down with the force of the springs
    It proberly won't cuz the springs aren't loaded but its a precaution just in case
    22nd May 2010
    21
    Thanks for the guide! Does anyone know the name of the plastic clips in the engine bay that secure the top of the strut as one of mine broke and i'll need to replace it. Thanks
    VXR enough Nurburg608's Avatar
    13th March 2009
    2,830
    I've got part numbers for them somewhere, but you dont need to undo them if you have the correct spanner to get at the top nut
    17th January 2012
    1,310
    Going to be tackling this at the weekend - great guide and looks a lot simpler than other cars I've worked on before!
    Question though:
    Apart from the fact that the top of my strut is rusty as hell, what kind of spanner would actually fit in the available space? Would a normal offset 21mm ring spanner fit in the gap? Just looks too deep and narrow a hole to use anything but a socket, but then obviously you can't get a T45 torx onto the bolt?
    Just wanted to ask before I go and buy one specifically for this job.
    South Wales louise1982's Avatar
    17th March 2009
    799
    hi. just wondering what size torx bits etc i will be needing as i dont fancy starting this and not having everything ready lol. any help would be great please
    VXRacing ahead MattieB29's Avatar
    12th March 2009
    515
    Quote Originally Posted by louise1982 View Post
    For the bolts on top of the front struts you will need a 21mm swan neck ring spanner & a T50 male torx socket. (You only need to hold the torx in place to stop the piston spinning while turning the 21mm swan neck ring spanner to undo the nut) For all nuts and bolts below at wheel level on the damper all you will need is a 18mm socket and a 18mm ring spanner, a 17mm open end spanner is required to grip the rear of the drop link nut while this is un-done with a 18mm socket. Be careful not to use a spanner that is too wide, as its easy to slip off this nut and push off the rubber ball joint gaitor on the drop link, its impossible to pull the rubber back on due to poor design so if this happens you will require new droplinks as I think they only come in pairs.
    Basically all tools required for the fronts are:
    * 1/2 Drive + Extension Bar.
    * T50 Male Torx Socket
    * 21mm Swan Neck Ring Spanner.
    * 18mm Socket.
    * 18mm Ring End Spanner.
    * 17mm Open End Spanner.
    * Spring Compressors.
    * Pair Of Grips. (For strut clips)
    * Wire Brush. (To clean out base of strut)
    * Jubilee Clip. (To be fitted under piston gaiter to stop piston rod dropping down. This is optional but can be a life saver as they are a pain to pull out)
    * Rubber Mallet. (Handy to have nearby)
    For the rears all you will need is a E20 female torx socket to undo the bolt on bottom of damper. Obviously axel stands and a trolley jack are essential.
    Rest-In-Peace 'James Tierney' 18.9.1991 - 16.10.2010
    Rest-In-Paradise Angel, 'Kirsty Malin' 5.12.1990 - 21.8.2010
    "Out The Way 4|2 Commando RM Taliban Hunter VXR Coming Through"
    17th January 2012
    1,310
    Quote Originally Posted by MattieB29 View Post
    * 18mm Socket.
    It's amazing the response you can get on a forum for having a pair of breasts!
    Top post - good work.
    Hellfrauds were ******* useless for the tools required for this job i.e. offset ring spanners and the E20 Torx. I ended up buying a through-socket ratchet set from them on trade card (hoping it'll come in useful again in the future....) and borrowing an E20 off a colleague as the largest Hellfrauds do is an E16.
    30th August 2009
    10,442
    Quote Originally Posted by jamesy_m View Post
    Hahaha !!
