Results 1 to 10 of 15
    The dancing Stormtrooper
    26th May 2009
    1,982
    Exclamation Standard M32 diff question?
    My car just started to make a clicking (not whining) noise. Best way to discrib it is like a disposible camera
    It gets faster and slower according to the speed of the car and the noise stops if the clutch is fully pressed or car not in gear. 1st thoughts was the standard diff? Anyone got any ideas?
    ps getting it checked out in an hour by my mechanic
    VXR enough chrissyb's Avatar
    22nd December 2008
    2,685
    sounds very gearbox related to me mate, could be several things ie clutch release bearing etc
    VXR Nothing comes close Rabbid's Avatar
    10th July 2008
    16,187
    If you're rolling with the clutch pressed and the problem was differatial related then you'd expect to keep hearing the noise
    Clique #14
    26th May 2009
    1,982
    Hope not gearbox is so much more than a standard diff. Weird how there has been a big increase in gearbox problems recently.
    26th May 2009
    1,982
    Quote Originally Posted by Rabbid View Post
    Thats why I thought clutch but I called my mechanic and he said the diff was making a slight noise recently. But I never have any problems getting in gear or slipping, more than likely because I never launch the car lol How ironic
    Are you VXR enough?
    11th February 2010
    959
    CV Gator split?? if they split and lose the grease they click (ignore it would do it if was in gear or not)
    sounds like clutch related
    Remus Cat Back down pipe, Dap Rs. 13.8 on 1/4 mile 259.7 bhp on the rollers STANDARD MAP!!!
    26th May 2009
    1,982
    And now it's stopped??? Getting a better look over tomorrow to be sure
    26th May 2009
    1,982
    This phantom noise decided to come back. I took it to my mechanic for a quick check/drive and of corse just before I got there it stopped. Now it is back so I did some test of my own until it goes on the ramps. So far this is what i have found:
    Makes noise only when in gear, it clicks and doesn't wine.
    If in gear and clutch is fully pressed no noise
    If out of gear no noise, even if moving, or revving
    No problems changing gears, nothing slips
    No boost issues
    Noise comes and goes when it wants, I was on a straight road (motorway) with cc on, the noise was there for 10mins then was gone for 20mins etc
    Sorry for essay, if anyone has anymore clues that would help, especially with diagnostic cost
    VXRacing ahead
    28th January 2011
    746
    Is it worse or does it change in any particular gear? Does it change in speed in different gears? Under acceleration, deceleration?
    26th May 2009
    1,982
    Same in all gears, gets faster with speed. Slows down if decelerating.
