Results 1 to 7 of 7
    4th May 2011
    53
    Unhappy Vibration/judder through steering wheel?
    Not sure how to best describe this but i'll give it a go. After a spirited B road drive friday evening I noticed that when turning left at approx 30-40mph theres a vibration/judder from the left hand wheel and through the steering wheel. Also happens in a straight line over 60ish mph but its not as bad.
    Does anyone have any idea what this could be or experienced this themselves?
    NOTE: I had Eibach springs fitted about 2 weeks ago and as of yet havent had time to get the tracking sorted. Was booked in to the garage at the weekend but had to cancel due to work.
    Want to get it looked at and rectified asap as the misses uses it for work everyday and dont want anything bad to happen when shes driving.
    Any help/ ideas is greatly appreciated.
    Thanks in advance,
    Karl
    Regional Organiser - Southern scorer's Avatar
    23rd May 2009
    5,447
    Sounds to me like the wheels need balancing mate. shouldn't cost much to sort.
    VXR enough jonny23's Avatar
    12th December 2010
    4,371
    There's a recent thread on this if you do a search. I'm having a similar problem with vibration at 70.
    From what I've read could be - tracking, balancing, wheel bearing, buckled wheel, tyre pressure.
    12th December 2010
    4,371
    Ps had my wheels balanced and didn't solve it so still looking for the answer. Going to swap front and back wheels next and see if it still does it
    VXRed blooded chrisw_vxr's Avatar
    19th August 2010
    474
    Check the discs and pads mate might need skimming or replacing
    4th May 2011
    53
    Cheers scorer. I'll get the tracking and balancing done asap. Hope it is something as straight forward as that.
    Jonny, tyre pressures are fine and not been over any potholes or bumps bad enough to buckle a wheel that I can remember. I guess the garage can tell when balancing?
    Chris, I'll check the discs and pads also. Hope it isn't them as they have only covered around 4500 miles.
    Cheers all
    23rd May 2009
    5,447
    Can't see it being anything except balancing mate
