Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    6th April 2010
    467
  2. #12
    6th April 2010
    467
    Hello. I bring good news. Got the gearbox fixed. Replaced all 8 bearings and 3 oil seals.
    Everything is ok. Car drives like new now.
    I wanted to ask you guys: when cold, after it has been turned off for 8-9 hours at 7-14 degrees celsius it goes out and in to gear a little hard. It does this from the day it was new.
    They told me that because the box oil is cold and until it gets to temperature.
    After 10 min of gear changeing is ok.
    I replaced the crappy GM oil. Engine oil is now Castrol and gearbox oil is full synthetic Mobil.
    Is this ok? Do you experience the same problems?
