Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 43
    13th November 2010
    37
    Default rear brake caliper piston can not get it back in helppppp
    Well front brakes are done but i have been on the rear ones 4 hrs now someone please save me !! wife is going nuts on me lol.
    I have replaced the rear pads but cannot get the rear piston to go back in so i can get the caliper on over the new brakes.
    I have undone the brake reservoir cap and have screwed the piston clockwise with some pressure on it at the same time but no luck what am i doing wrong please? i have screwed it in at leaset 30 times but it does just not seem to be going inside? i also opened the bleed nipple but no different just got messy lol
    Regards
    Jeremy
    VXR Nothing comes close coreythorny's Avatar
    4th March 2011
    22,600
    As long as you have the fluid tank cap off, applying the pressure in the right place and turning it the right way it should go.
    Make sure the whole caliper is dead cold to stop any thermal expansion and you could try carefully applying some penetating oil to the piston walls to see it helps.
    13th November 2010
    37
    hi, many thanks for reply been on this hours but getting no where fast. i just appy the pressure in the middle of the piston ? is that right and just been turning it anticlockwise. its cold and fluid cap is off. just does not seem to be going back in do i remove the rubber case behind the piston to see whats going on?
    4th March 2011
    22,600
    Quote Originally Posted by jsansomvxr View Post
    I'm yet to change my rear pads/discs myself but know some people have had a bit of trouble with them.
    Some people have also removed the caliper and got it in a vice to help hold it whilst turning the piston. You could try having a search as I know there's stuff on here about it.
    11th January 2006
    2,202
    the n/s/r caliper is left handed thread so make sure you are winding it in the corrrect way
    13th November 2010
    37
    Quote Originally Posted by timmee View Post
    I tried turing it the other way and it started to come out so def turing it the right way lol
    4th March 2011
    22,600
    Anti-clockwise is correct.
    VXR Where am I Mr I.T guy? jalfrezigazee's Avatar
    14th July 2007
    4,644
    I have a tool to do this and even with the proper tool it is a right pain to do. You need a huge amount pf pressure on it while turning. Tool was about £20 a kit to do any rear setup. Sure it has paid for itself a few times over done 5 sets of rear pads on my motors
    Astra VXR Stage 2, 279.7bhp Petrol, 292.0 bhp LPG
    VXRacing ahead
    17th October 2010
    500
    I did mine myself was difficult though. Think i used a hammer with the end of the shaft pushing the piston in and used pipe grips just to twist it back and forward not winding it either way just going about 90 degrees back and forward. Good luck!
    13th November 2010
    37
    yeah i have give up now lost the light will try again tommorw nightmare! i have also ripped all the rubber that is around the piston will that be ok ?
    wish i had took the rear ones to a garage front were easy!
    Many thanks for help and advice so far all
    Regards
    J
