Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 43
  1. #21
    VXR enough DRC 72's Avatar
    22nd April 2011
    4,456
    Quote Originally Posted by watoo vxr View Post
    Sorry but......+2!
    Sent from my HTC Wildfire S A510e using Tapatalk
    Lol epic fail lol
    Sir Dale Of Yorkshire
  2. #22
    13th November 2010
    37
    I guess that’s an obvious thing then handbrake off !! no wonder i have had no luck with rear piston all day front ones were perfect though with the brake on lol
  3. #23
    VXR Nothing comes close coreythorny's Avatar
    4th March 2011
    22,600
    Mate we all do things like this.
    I'd rather make a silly mistake like that a big one anyday!
  4. #24
    VXR Nothing comes close watoo vxr's Avatar
    8th February 2011
    10,037
    Quote Originally Posted by coreythorny View Post
  5. #25
    13th November 2010
    37
    Cant beleive it !! wont a dumb A@@ i am lol. Will the rubber be ok thats around the piston i have ripped it quite a bit where i was turning and turning the piston? i think it just helps protect water from getting in the piston?
    Regards
    Jeremy
  6. #26
    VXRacing ahead
    17th October 2010
    500
    Quote Originally Posted by jsansomvxr View Post
    Regards
    Jeremy
    As long as theres not brake fluid coming out you should be ok. When youve got them fitted press the brake a few times then check the caliper.
  7. #27
    VXR Where am I Mr I.T guy? jalfrezigazee's Avatar
    14th July 2007
    4,644
    you will need a seal kit. With them ripped salt and dirt will get in and the pistons will rust up quite quickly. Will need a replacement caliper then
    Astra VXR Stage 2, 279.7bhp Petrol, 292.0 bhp LPG
  8. #28
    5th May 2011
    120
    One thing that will make pushing the piston back easier is to undo the bleed nipple when you turn back the piston, but make sure you have a bleeding bottle on the nipple of fluid will go every where
    60 plate Ardon blue corsa Vxr
    Ex MG/Rover tech
    Chevrolet technician
  9. #29
    10th January 2011
    78
    Hi,
    I changed my brakes (front and rear) a few months ago, and I faced the same issue with brake piston for rear (left) caliber.
    My mechanic was totally unable to get the piston back in, so had to buy a new caliper... Maybe a common fault...
  10. #30
    2nd September 2006
    309
    Had the same problem with both my rear calipers, to cut a long story short driver side rear is rewound clockwise and passenger side is rewound anticlockwise. My hands where in bits took me two hours to rewind one.
    Owned a Corsa VXR once upon a time.
