Page 1 of 10 1 2 3 ... LastLast
Results 1 to 10 of 91
    28th September 2010
    424
    Default Limp Mode at high revs!!
    Hey guys this problem is still bugging me!
    I am TMS stage 2 and the car basically goes into limp mode when full throttle in 4th or 5th gear high in the rev range eg(4k-6k).
    I have replaced the following already.
    BCS
    Spark plugs
    Coil pack
    Now the car runs fine when the MAF sensor is unplugged so im thinking that it may be causing the issue.
    IS THERE ANYONE IN GLASGOW AREA WHO WOULD SWAP ME A MAF SENSOR FOR 2MINS SO I COULD SEE IF THIS IS MY PROBLEM? AS IT WOULD SAVE ME SPENDING OVER £130 IF THIS ISNT THE FAULT.
    any advice or help would be much appreciated.
    VXR enough wellsy_mush's Avatar
    6th August 2010
    1,703
    You made sure the waste gate arm is not hitting the precat V clamp. Mine went into limp mode at high revs due to this.
    Sent from Wellsys iPhone 4s using Tapatalk
    Rabbid Stage 3, Airtech front mount, GM Hids, Cobra Exhaust, Direct route ram air, EBC Disc's, Red stuff pads and Hel brake lines.
    The list goes on
    28th September 2010
    424
    Pretty sure it's not that as I went and bought a new clamp (£48!) and the car doesn't do it when the MAF sensor is unplugged?
    28th September 2010
    424
    Anyone?
    6th August 2010
    1,703
    Yer that's because it won't sens the air / flow in the system.
    A garage fitted my new clamp and ****** it up.
    The list goes on
    28th September 2010
    424
    I just went out and double checked it there and is on fine... The spring clamp part is around the back and away from the wastegate so don't think that's the issue...
    VXR enough SpoonVXR's Avatar
    31st January 2011
    1,398
    Any error codes because it sounds just like my boost signal problem I have just had fixed
    28th September 2010
    424
    110611 mate :/
    Regional Assistant - Scotland West jigger's Avatar
    3rd July 2008
    5,790
    thats boost pressure signal code is it not
    31st January 2011
    1,398
    Indeed it is and that is what I just had cured. As far as I could grasp it is the map, I just had a new remap put on and it works so well! No more code and limp mode
