Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 91
  1. #21
    VXRO's Bulging Eyes burgerken374's Avatar
    16th September 2008
    4,973
    I have had TMS S2 since April 2009 with no issues, but never max out the revs, two weeks ago took the car on track at Snetterton & at high revs EML light comes on & lose of power, check for fault codes & 110611 showing, clear it take it out again & same happens. We decided to put the standard map back on & no issues for rest of the day. I spoke to TMS on the Monday & they gave me all the same reasons. Its still running fine on standard map. Not sure if I want to run the TMS map again
    Astra GTC Summit White with Aero Pack, Navi 600, Rear Parking Sensors, Carbon Diffuser, Carbon Wing Mirrors, Carbon Front Scoops & Carbon Mud Flaps, & Splitter
    BMW Z4 sDrive 35is with DCT, 3.0 Ltr Bi-Turbo, Mineral White, Black Leather & Silver Carbon interior, 340 BHP, 450nm with 50nm 7sec over boost, 0-62 = 4.6sec
    'Clique' # 1
  2. #22
    28th September 2010
    424
    Well least I'm not the only one! Sounds like exactly same problem as me... Im trying to find someone to give me a 5min test with their MAF to see if this may solve it... Failing that I'm struggling!
  3. #23
    Regional Assistant - Scotland West jigger's Avatar
    3rd July 2008
    5,791
    if all is fine on standard then its map related and not maf........
  4. #24
    11th September 2006
    444
    When my boost pressure sensor played up just take it off blow it out with an air line put it back problem sorted for a few months
  5. #25
    28th September 2010
    424
    I've changed my boost solenoid already didn't seem to help
  6. #26
    VXR enough SpoonVXR's Avatar
    31st January 2011
    1,398
    Quote Originally Posted by Andy91 View Post
    Same here until i got my remap.
  7. #27
    VXR School Run, All Aboard! SilverSchoolBus's Avatar
    8th February 2009
    7,474
    Join the club, am running t*s stage 2 map for two years, again, never really run high revs and when I did last week, the bus went into limp mode and with the fault code above too.
    Mine overboost to 24! And 20 holding. I adjusted the actuator and it overboost to 22 and 18 holding now. I will go to another tuner as soon as fund is available. I will ditch the bluefin as I don't want to see another vxr getting ruined.; ).
  8. #28
    28th September 2010
    424
    Took the Re-MAP off there guys and tested on a PRIVATE road. Still doing the same thing... High up the revs in 5th gear this time!
    Got home allowed the car to cool down and then checked codes via pedal test 110611....
    Rather P***ed off! So don't think it's just to do with the TMS map
  9. #29
    3rd July 2008
    5,791
    well rules that out then think you should be looking at maf then.....
  10. #30
    28th September 2010
    424
    Any ideas where to get one? eBay is £125 for a Bosch one :/
