Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    That's a nail in the tread! thereplicant's Avatar
    16th March 2011
    2,910
    Default Vectra VXR Squeaking!
    Morning guys, my car is squeaking.
    Going forward and turning at low speed, high pitch squeal type sound. It did it a while back and I told Vauxhall when they did the service and they never heard it and to be fair I didn't either when I picked the car up but I covered another few hundred miles and it's started again, very loud, loud enough that everyone looks at you!
    Any ideas?
    It's just out of warranty as well. So an 09 with low mileage.
    Any advice is appreciated.
    Sent from my iPhone....
    VXR enough Richie Russ's Avatar
    5th December 2007
    4,667
    Not the brake disc covers on the front mate?
    16th March 2011
    2,910
    Does sound like its coming from the front, do the covers rub Richie?
    5th December 2007
    4,667
    Yes mate, when I changed my front discs and pads a few weeks back I prised the little covers behind the discs away as they tend to rub, no more noise, so worth a go, wheel off 2 second job.
    VXR enough chrisvectra's Avatar
    5th August 2008
    2,554
    its a tiny little lip on the rear of the disc fella found this out when i changed the front discs and pads very recently, take the wheel off and turn on full lock its a tiny lip but makes a hell of a noise if its touching the disc. also check your power steering fluid level as well as low fluid can make it squeel as well.
    VXR IS FOR LIFE NOT JUST FOR THRILLS!!
    16th March 2011
    2,910
    Thanks guys I'm just home after 100 miles of squeak! Worse when turning right. Will have a look later and report back.
    Are you VXR enough?
    7th June 2009
    754
    id say dust shield scraping on the back of disc,i had it on mine,sounded like one of them american trains on the railtrack lol,made people put fingers in there ears it was that loud haha
    16th March 2011
    2,910
    Do the wheels need to come off for this? Can I not just put full lock on and use a long thing ........
    VXR Torque of the Devil vxrossco's Avatar
    16th July 2009
    9,558
    Quote Originally Posted by thereplicant View Post
    Its easier with the wheel off I find as you can get better access to move it out the way but you can do it with the wheel on just more awkward
    #1
    5th August 2008
    2,554
    easier with the wheels off bud
