Results 1 to 6 of 6
    400HHP monkey racer VXRDean's Avatar
    13th August 2006
    7,338
    Default HOW TO remove front bumper
    Hi, All, could anyone, please tell me , how to remove the front bumper.
    New headlight to replace soon, cheers.
    6th April 2008
    54
    take the top grill off, either 4 t20's or 4 push centre retainers, if its the push retainers then make sure you dont lose the centres. give the grill a firm tug to get it off. there should be a couple of bolts underneath. then there should be two in each wheelarch, and there might be a couple underneath. i may be wrong about the ones underneath. then you may need an assistant, you have to push the bumper just after the wheel arch, then at the same time pull the wheel arch edge of the bumper. it should pop off, with one side off disconnect you headlamp washer hoses if fitted. and disconnect front fog lights and the outside air temp sensor. then pull of the other side of the bumper the same as previous. hey presto!
    13th August 2006
    7,338
    Thanks a bunch mate!
    VXR SMD/LED Man vxrcourt3's Avatar
    8th November 2007
    4,647
    dont forget to remove push retainers from the bottom belly pan, as there are 3 that fasten to bottom back of bumper....
    WHICH ONE TODAY.... ???
    LAMBORGHINI LP560-4.....VXR8 BATHURST:S...or.....FOCUS RS
    6th April 2008
    54
    no probs! if you run into trouble, send me a pm. or add me on msn
    6th April 2008
    54
    Quote Originally Posted by vxrcourt3 View Post
    ahh. i wasnt sure. there either push ones, or there ones with pull out centres.
