Results 1 to 1 of 1
Thread: TOTAL VAUXHALL FORGED Regal stage 4 vxr conversion 350BHP only 10,275 miles
    VXRed nathj's Avatar
    29th August 2011
    213
    Default TOTAL VAUXHALL FORGED Regal stage 4 vxr conversion 350BHP only 10,275 miles
    Here for sale we have my Regal stage 4 vxr conversion that has last month just been featured in TOTAL VAUXHALL magazine issue 136.
    The car started life as a 2.0 turbo sri 170bhp, from then it has had a full VXR Z20 LEH conversion.
    All in all i have spent thousands getting the astra how it is today and getting it into total vauxhall magazine.
    during its life it has thousands spent at AJK motorsport , regal autosport , courtney sport and MPG garage which are all BIG vauxhall tuning companies.
    First of all was the conversion which was a 2009 Z20 LEH engine out of a nurburgring edition, This work was carried out at AJK motorsport.
    Once the old engine was out it was time for big power with the build.
    Paul at AJK got to work stripping down the vxr engine and rebuilding it with all FORGED COSWORTH components giving it 10x the strength to cope with the BIG BHP.
    Being a brand new engine the best oil and filters where fitted and had to be run in for 1000 miles before its first service.
    Once done so AJK fitted BBS CH alloys and KW fully adjustable coilovers. This set up was lazer aligned for the best results.
    2nd was COURTNEY SPORT where it all all new pipe work set up, including a big front mount intercooler , cool running thermostat and bigger uprated pendulem for increased air flow.
    3rd was MPG garage for the re-circuit valve , dump valve and most important the uprated fuel pump ready to cope with the new turbo.
    4th was the last stop at REGAL AUTOSPORT where the uprated ko4 hybrid turbo was fitted giving it more power on boost.
    Before all remap work could be carried out a uprated regal clutch was fitted along with a lightend and balanced fly wheel, also to go with that regal supplied a cast manifold and a custom 2 stage map, They spent hours tweeking and tinkering with the map to get it the best they could and finally got it to a stage 4 set up.
    The results of this where 350BHP and 375LB torque, an absolute animal.
    The car has only covered 10,275 miles , this millage will not increase by much as at the moment is being used as a weekend car. The only real millage it will be putting on between now and selling will be to travel to this years PVS show at santa pod where it will be featured on stand for sale.
    The car is a 56 plate model as brand new, it is immaculate in everyway possible inside and out, it has been professionally supagared giving the paint work a garanteed protection for 3 years and is still currently under warranty. The inside has also been supagarded so it looks and feels brand new when you sit inside. Car has never been smoked in or mistreated since new.
    This car may be subtle looking but its seare power is not for the faint hearted please no time wasters or test pilots.
    spec list :
    FULLY FORGED VXR Z20 LEH CONVERSION
    BBS CH 18' ALLOYS
    KW FULLY ADJUSTABLE COILOVERS
    REGAL CAST MANIFOLD
    SCORPION PRE DE CAT
    MILTEK RACE CAT BACK EXHAUST
    REAR TINTED WINDOWS
    FORGED RE-CIRC VALVE
    1.9 CDTI AIR BOX
    ITG FILTER
    REGAL CLUTCH HOUSING WITH UPRATED PLATE
    REGAL LIGHTEND AND BALANCED FLYWHEEL(please note all uprated clutches do have a cetain amount of noise to them)
    REGAL UPRATED RELEASE BEARING
    TX AUTOSPORT FRONT MOUNT INTERCOOLER
    MPG UPRATED FUEL PUMP
    BAILIES DUMP VALVE
    COURTNEY SPORT RED HOSES
    COURTNEY 80MM AIR FLOW METER
    COURTNEY UPRATED INJECTORS
    REGAL STAGE 4 CUSTOM REMAP
    REGAL UPRATED HYBRID K04 TURBO
    REGAL UPRATED BOOST SOLENOID
    REGAL MAP SENSOR
    REGAL UPRATED ACTUATOR
    COURTNEY COOL RUNNING THERMOSTAT
    AJK UPRATED HEAD GASKET
    AJK BALANCE SHAFT DELETION KIT
    COSWORTH RODS
    COSWORTH PISTONS
    COSWORTH CON ROD BEARINGS
    RED ROCKER COVER
    ARDEN BLUE VECTRA V6 BRAKE UPGRADE
    PIANO BLACK DASH
    STACK BOOST GAUGE 2.0 BARR
    COLOUR CODED V GRILL
    COLOUR CODED BOOT HANDLE
    DEBADGED
    REAR WIPER REMOVED AND PLUGGED
    VIEWING IS 100% RECCOMENDED WITH THIS CAR TO BELEIVE HOW CLEAN IT IS.
    all recipts are kept in a file and will be sold with the car, Also a copy of issue 136 total vauxhall feature will come with the car.
    For any questions please email or phone , i am open to any sensable offers.
    PLEASE NOTE PRIVATE REG IS NOT INCLUDED AND WILL BE REMOVED.
    !!QUICK SALE NEEDED DUE TO WORK COMMITMENTS!!
    £9,295 , i am open to any sensable offers
