Results 1 to 7 of 7
    15th October 2012
    30
    Post Corsa VXR Back Whistle
    any ideas on this one guys?
    When putting an air filter on my car you get the good sound from the secirculatory valve but it's followed by a nasty back whistle?
    Sounds somewhat like this;
    http://www.youtube.com/watch?v=0h4JYhZb03A
    any ideas what causes that? I've seen some cars with the same set up that don't have the same issues?
    Cheers!
    VXR enough Nupzyo's Avatar
    1st July 2012
    1,263
    My piper did this, just thought it was normal?
    Nupzyo's Arden Corsa
    - Cobra full decat - Smoothed front bumper - PI 30/20 - Full SMD - 17" Rota Grids - Heko's - Black, Blue and Chrome Engine Bay - Full Courtenay Sport Hose Set - Forge DTS Bar - Rear Boot Brace - RSPEC Gauges - Courtenay Sport Panel Filter & Cold Air Feed - Blue Conduit -
    15th October 2012
    30
    I'm guessing it maybe is just would rather it didn't still sounds awesome just would probably rather without the wee backwhistle?
    Just wondered if anyone had a work a round :P
    VXR enough gary-smoke's Avatar
    8th July 2012
    1,342
    Mine sounds like this with a pipercross
    Sent from my Nokia 3310 using chalk and a blackboard
    newcastle upon tyne
    gary-smoke@live.co.uk
    VXRacing ahead
    1st November 2010
    507
    mine the same quite like it very loud,depends which cone
    VXR Nothing comes close James H-S's Avatar
    14th February 2011
    12,706
    Sounds normal
    Red Corsa VXR Gone! # BMW 118D arrived
    5th April 2009
    93
    I have k/n cone with samco hose its normal .
    Want to make ur car sound like a turkey lol take diverter valve pipe of turbo and stick a bolt itto the pipe. Then drive. All waste air will dump throw ur filter.. But dont drive to hard ur valve will lift at around 13psi and ur car will run poo.
    Or get a dumpvalve.oem dv blank plate and reroute the boost pipe to the sensor on the back of inlet manifold. Thats how wayne/vxrs runs.. . Waaaaatussss
