Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
  1. #21
    3rd November 2012
    19
    Quote Originally Posted by zefal View Post
    lol I thought that he had moved on and I can help with that, but thought I would check first.
    This is what I did to power amp;
    There is a hole behind the glovebox you can use (slit the rubber on the side - it's a big grommet) to route the positive power cable
    Then run it down the passenger side of car... I took off the plastic cover down the side of passenger door.
    The tricky bit was getting the cable through behind the rear passenger panel (where the rear speaker is) as I didn't want to remove it completely... I cheated and attached the cable to a garden cane and pushed it up through to the boot and pulled it through the access panel to fuses on left hand side of boot. Did the same from phono/remote cables to back of HU too.
    I can't remember where I earthed the amp to, but it was probably a seat belt bolt for rear seats?
    Hope this helps.
    Yeah thanks for that, How easy is it to get the power cable through the grommet ? i know they are a real pain any tips on best way of getting wires through it ?
    cheers
  2. #22
    VXR enough zefal's Avatar
    22nd May 2011
    1,334
    I juts made a small slit towards the bottom right of grommet. Went through easy enough and my power is really thick with 80 amp glass tube fuse! I'm sure a small amount of Vaseline would help the cable through if required too.
    Stage 3 Arden Astra GONE
    Hello EVO 9 FQ-340 (now 420 BHP/ 430 ft-lb/s)
  3. #23
    VXRed jonnyvaux's Avatar
    5th November 2012
    62
    Quote Originally Posted by graeme73 View Post
    excellent, thats just the info i was looking for, the blue led dash looks amazing, have to get on the case now! thanks guys.
