Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 72
  1. #21
    Are you VXR enough?
    21st September 2010
    891
    Basic internals have been known to run up to 270 bhp so remap fine unless your pushing piston 4 only happens when people don't let car warm up and cool down and get new engine and if you want to back your self up and forge it if you wanna be safe but people are running on stage three and ain't hada problem
    Arden blue Astra gtc vxr recieved happy as
    Options- aero pack/navi 600
  2. #22
    VXRed blooded Ali VXR's Avatar
    22nd October 2011
    405
    Their **** engines, mines an 11 plate with 13K miles and I'v got P4... f*ckin ridiculous spending £15K on a car and it spends most of the time in the garage :@
  3. #23
    30th December 2010
    3,208
    Driver error.
    I've never had an issue with mines and its 57 plate.
  4. #24
    VXR Nothing comes close Pnut's Avatar
    22nd December 2011
    10,067
    I had no problems running stage 3 on standard internals for 15k.. only forgued due to going further than stage 3 not because of any problems... at the end of the day warranty is there to protect against these things happening if you are standard... if you choose to mod your car then you make the decision to deal with the consequences yourself when things happen.
    Built by WG Motorworks
    Clique #9
  5. #25
    13th May 2012
    56
    Got told it could have been to much fuel goin in n maybe ats y it was makin the bangin noise but would this coz conrod to go the sump? Combustion would it be to much for the rods? If a had to go get the engine stripped then put steel conrods what other parts would a need guys ? Cheers
  6. #26
    13th May 2012
    56
    Think at what it was m8 car was cold yep Defo learned the hard way
  7. #27
    VXR Torque of the Devil vxrcopey's Avatar
    1st June 2010
    5,087
    P4 only goes if
    1. The map hasn't been correctly modified with your hardware
    2. You have been driving like a faggot/ person before you
    Daily Mk7 Golf R - Nortech Corsa Track Car !
  8. #28
    VXR Nothing comes close coreythorny's Avatar
    4th March 2011
    22,600
    Quote Originally Posted by vxrcopey View Post
    P4 only goes if
    Or when you turn the key
  9. #29
    1st June 2010
    5,087
    Quote Originally Posted by coreythorny View Post
    Hahaha!!
  10. #30
    Interceptors cant catch this.. mcpaynter's Avatar
    21st April 2011
    11,438
    Quote Originally Posted by Mickfloyd View Post
    Cars not to low looks gd a head turner, well that's what a think it is conrod thro sump tho was checking spark plugs one on the right was twisted n melted abit so could be piston has caused it, just guessing the now tho waitin on garage lookin at it
    Head turner because of the scraping sound.. Or because they are wondering if your suspension has collapsed
    No VXR
    Abarth and a 330e
