Results 1 to 10 of 12
    6th August 2012
    70
    Exclamation Help! Cone filter fitting
    I bought a pipercross cone filter for my sri 1.6t... I have read both here and on corsaduk that some people have left the bottom half of their airbox on when fitting a cone filter as it doesn't restrict airflow too much, protects from engine bay heat and provides some stability for the cone..
    I took the top half of the airbox off, however I have previously read to leave the bottom half on to increase stability of the air filter and it shouldn't restrict airflow.
    It doesn't seem to fit right and the foam of the air filter has been pushed in by the bottom half of the airbox. What have other people done when fitting their cones? Is this the correct fitting?
    VXR Nothing comes close James H-S's Avatar
    14th February 2011
    12,706
    That look exactly like mine
    Red Corsa VXR Gone! # BMW 118D arrived
    6th August 2012
    70
    Quote Originally Posted by James H-S View Post
    Ah thats good to hear!
    So it shouldn't be a problem that the foam is dented in and that's the recommended method over removing the whole air box?
    Cheers mate
    6th August 2012
    70
    One more question - When accelerating or I push the accelerator there is a constant suction noise which then obviously hisses when the accelerator is released. I knew about the hiss of the re-circulation valve however i presume the sucking noise before is also normal?
    VXRed Haymaker's Avatar
    20th March 2012
    136
    Yes its the turbo spooling.
    14th February 2011
    12,706
    Quote Originally Posted by GeorgeFitzz View Post
    Yes completely normal.
    5th March 2012
    43
    What size is this cone?
    VXR enough OGA11Y's Avatar
    30th July 2012
    2,839
    Quote Originally Posted by Tomg3 View Post
    200x200
    CORSA VXR
    SCOTLAND NORTH
    VXRed blooded rome_2_instanbul's Avatar
    5th June 2012
    458
    On your SRi? the picture shows a VXR?
    Flame red VXR | Milltek 2.5 Full system | TX FMIC | Custom Remap | K&N Panel Filter | Forge Intake | Eibach Sportlines | EBC Grooved discs and pads | Gloss black 18's | HEKO's | Debadged | Silvatecs | 228 BHP
    6th August 2012
    70
    Quote Originally Posted by rome_2_instanbul View Post
    Its the same engine............
