Results 1 to 1 of 1
    VXR Sheep Mad vxr-blacksheep's Avatar
    15th October 2007
    2,784
    Default My astra rss 360 for sale
    Provisionally sold due to go to its new home on Saturday , thanks for all the interest
    Well the time has come , loved every minute of owning , modifing and developing this car . so the spec is as follows -
    Astra vxr in Arden Blue, 57(sep) reg , 33500 miles , full service history from vauxhall and Regal , MOT till sept 2013 , last service was sept 2012 , tax till end of march 2013
    INTERIOR
    Half Leather
    Blue SMD conversion
    Piano Black
    Boost gauge pod
    OPTIONAL EXTRAS
    CD70 Sat Nav
    Sight and Light
    Push Button Start Stop
    Keyless Entry
    Cruise control
    EXTERIOR
    Matt Black Wrapped Roof , Rear wing , Boot strip , Rear diffuser
    Tinted Wrapped Front Rear Lights
    ( All above wrap can be taken off and put to standard )
    Rear tinted /privacy glass
    WHEELS , SUSPENSION , BRAKES , GEARBOX
    Light Weight 19 " TD 1.3 in Mojarve Brown Wrapped in Michelin pilot sport 2 at the rear ( plenty of tread) and 2 recently put on duel compound michelin pilot supersports
    KW Variant 3 Coil overs ( fully adjustable compression , rebound and height )
    6 pot mono block Brembo caliper with 390mm rotor with ally bell ( RS6+/R8 Kit simply Awesome )
    WaveTrac LSD
    MODIFICATIONS
    CDTI Air Box
    REMUS Exhaust
    Regal Stage 2 intercooler
    Dbilas cast manifold with Hybrid Dbilas GT28 turbo
    Dbilas air intake scoop
    EVO-MS Recirc Valve
    Regal / EDS inlet manifold and top hat with thermal gasket
    630cc injectors with fuel pressure regulator and uprated high flow fuel pump
    Regal inlet cam with uprated springs and platforms
    16 bar mocal oil cooler
    All work carried out by Regal autosport , only ever run on shell v-power with over 10K of mods in parts alone . A true fast road or track car with stunning performance and handling .
    An avarage power of 350-360hp and 320-330lbft of torque at 1.2 bar ( drop in a set of rods and a bit more boost and its an easy 400hp car )
    £11000 ovno
    heres a few pic from a couple of weeks ago
    if asking price is met i will throw in all the spare part i have as follows -
    standard inlet manifold
    standard front brake calipers
    standard 19" wheels in minstrel grey
    1 spare tyre
    arden blue rear boot strip
    baileys DV
    standard springs
    standard pre cat
    probably a few other bits about to
    Thanks for looking pretty sure i ve got it all there lol please PM for further info
