Results 1 to 9 of 9
Thread: Esp light on
    22nd December 2011
    152
    Default Esp light on
    I got in my car last night and wasnt in the best of moods so i floored it in 1st and second, the esp/traction light was flashing as i was wheelspinning and now the lights still on and esp isnt active atm ..
    18th February 2007
    51,382
    Tends to be AFM related when the ESP stays on - go check the Error code thread in the How to section and learn how to get the error codes off the car
    Astra
    22nd December 2011
    152
    Checked for codes but the only ones that come up is the 042011 because of decat and 161450 which says about sumin to do with the key :/ not noticed anything wrong with that , but no code related to the esp.. Any one ever had this problem? pretty annoying in the low gears , especially in this rain now
    VXR Evil Monkey Cerberus's Avatar
    1st September 2008
    7,253
    disconnect battery for 10 mins , should reset it
    Quote Originally Posted by soosie View Post
    22nd December 2011
    152
    No didnt work, it removed the emissions one , but i know tht will keep popping back, any one know what else.. The traction control isnt work .. Not a fuse? Havent checked tht
    Not the standard VXR
    19th April 2011
    1,144
    What happens if you try and disable and re-enable the TC?
    13th March 2012
    347
    prob a bit of crap on the abs ring on the hub! what other lights are on? could be u have disturbed the plug on the front leg!
    22nd December 2011
    152
    Nothing happens when i try that , and yes i think tht must be the case where ive disturbed the plug.. Anyone know where to find this plug to fix it..
    22nd December 2011
    152
    It was caused when i wheel spinned in 1st turning right , stupid i know..
