Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    Are you VXR enough? BirdsEye's Avatar
    12th August 2012
    900
    Ok thanks, would that not cause an error when doing the pedal test though? Or do you think its working, but just the plastic seal is split?
    Grey I take it you mean line off vac box to re-circ valve?
    Astra VXR - 19s, AFLs, cruise control Mods - Pioneer AVH-8400BT HU, 3" Piper turbo back exhaust, cdti direct route hose w/ pipercross cone, Forge re-circ valve, 15mm H&R spacers...Rabbid Tuned
  2. #12
    VXR enough meeeees's Avatar
    22nd June 2012
    1,264
    normally it doesn't cause fault codes, and yeh the rubber diaphragm splits. Everyone fits uprated ones, either the forge or the cheaper (and practically identical) ebay version: http://www.ebay.co.uk/itm/ASTRA-CORS...item3a7df306f9
  3. #13
    VXR Torque of the Devil Grey's Avatar
    19th July 2010
    7,103
    no it wouldnt cause a error code, and yes it is worth while doing this replacement of re-circ valve. A friend of mine has done 56,000 on original turbo and re-circ valve he had the flutter sound so we replaced this valve for a forged one, it turned out nothing was wrong with original re-circ valve and vac line was off vac box.
    Clique No.10
  4. #14
    12th August 2012
    900
    Ok guys cool, another noob question (sorry about this!) would you guys recommend a blanking plate, or the one way return valve...or nothing at all?
  5. #15
    19th July 2010
    7,103
    NO! have a uprated re-circ valve never blank it!
    Clique No.10
  6. #16
    12th August 2012
    900
    Cool Grey thanks! Will get one ordered one ASAP! Thanks again guys.
  7. #17
    VXR enough NuttyVXR's Avatar
    8th December 2011
    1,024
    Quote Originally Posted by BirdsEye View Post
    Thanks for the advice guys, I will look at all of the vac lines. I will also put everything back to standard and see if the issue remains. I wasn't aware having a cone caused flat spots, I thought that was just the crossover pipe?
    My car still did it with a direct route and cone, only went when I had it mapped!
  8. #18
    12th August 2012
    900
    Ahh OK, cheers for the info mate, its getting mapped next week so fingers crossed it will go. Just wanna make sure its all 100% before it gets mapped ideally.
  9. #19
    19th July 2010
    7,103
    Who ever maps it if they read knock readings etc they will be able to tell if a vac hose is off... If they look lol who is mapping it? Excuse me asking
    Clique No.10
  10. #20
    12th August 2012
    900
    Its Shark performance remapping it mate. They are new to the Vauxhall scene but are very well known with VAG remapping. I trust them 100%, but just to be safe I will be getting a forge re-circ valve and a few silicone hoses. Thanks again for your help!!
