Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 46
  1. #21
    Mr Franks.... dannyf's Avatar
    9th December 2007
    8,321
    to do it with the head on you need a air compressor
    the truth is out there
    part GSI part VXR
  2. #22
    9th December 2007
    8,321
    me I like to take the head off and also clean up the valves and pop the head in the dunk tank and clean all the carbon off it
    part GSI part VXR
  3. #23
    VXRacing ahead
    25th February 2013
    512
    Can anyone explain how its done? If so I will change both the turbo and stem seals
  4. #24
    VXRacing ahead
    25th February 2013
    512
    Quote Originally Posted by dannyf View Post
    Very true. It's all money that could do without spending. Head gasket set, stretch bolts, water pump, timing kit around £200-£250
    With turbo and gasket set £440
    Ouch...
  5. #25
    VXRacing ahead
    25th February 2013
    512
    Just to let you all know I've taken the turbo off thisafternoon and there is a lot of play in the outlet turbine. I'm hoping this is my cause.
  6. #26
    19th February 2012
    1,181
    It does sound like your turbo, but the tool to do stem seals is a 'sealey cylinder head service kit' although there are others out there. Basically you hook an air compressor into spark plug hole to pressurise the cylinder, this holds valves closed while you remove springs, seals ect. You obviously need to remove cams and other misc parts.
  7. #27
    VXRacing ahead
    25th February 2013
    512
    When I bought car few week ago the garage said it had a top end rebuild previous but we had no proof. I can see its had a new manifold gasket, timing belt, air filter, manifold studs so I assume he's correct and if so they would have done the stem seals at same time as they would have to of bought a head set and comes with them.
    Anyway I'm off to the dealer tomorrow to buy a brand new turbo. ;-)
  8. #28
    19th February 2012
    1,181
    £360 from Evan Halshaw on here. I wouldn't buy anything from Arnold Clarke
  9. #29
    VXRacing ahead
    25th February 2013
    512
    Quote Originally Posted by Fonzie2107 View Post
    Evans halshaw is where I'm buying from. They're price is awesome. Company's want that to recondition my unit. Stuff that. A brand new one will do me.
  10. #30
    19th February 2012
    1,181
    Yeah its a good price. I was confusing arnold clarke with another thread i think
