Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: LED lights
    22nd April 2011
    116
    Default LED lights
    Im looking at changing my rear light clusters and front indicator bulbs to LED's and wanted know if anyone has done this and what was the best site they used and any problems they came across that i could hopefully avoid.
    17th February 2013
    115
    Front led indicators look gash and will more than likely cause a fault. Just but silva techs mate.muvh smarter and about 2.89 of eBay I think
    VXRed blooded Brad's Avatar
    19th July 2008
    456
    I tried this a while back but have not yet found a set of LED bulbs that dont bring up a fault and flash fast, i've now given up searching because i'm fed up of buying LED bulbs to see if they work, if you find some that work let me know
    - Corsa VXR - Arden Blue - Sight & Light Pack - Front Grill VXR Badge - ITG Panel Filter - Milltek Down Pipe - Milltek Catback System - TMS Bluefin Remap - Blue Samco Boost Hoses - Baileys DV26 BOV - 6000K HID Kit - Team Heko Wind Deflectors - 18" Black Vauxhall Alloys - Nurburgring Splitter - OPC Fog Surrounds - Tinted Fog Lights - CS Brake Ducts - Ultra Black Headlights - Tinted Windows - Hel Braided Brake Lines - Green Cotton Filter -
    30th March 2011
    127
    You need CANBUS error free bulbs and even then you might need a resistor kit to put I between. 12V going through an LED isn't good and as far as I'm aware that's what makes them flicker!
    Have a look around HIDs Direct website or give them a call...there really helpful
    VXR enough Cabbage's Avatar
    15th May 2012
    2,019
    Silvatechs ftw ! But pretty sure they're more than £3 or so, think I paid £9/10 - but definitely worth it to rid the tango'd effect
    VXR Sold
    Porsche Sold
    Hello Cupra
    19th July 2008
    456
    I've had silatechs in the corsa for the past 4 years, want LED's now lol
    27th March 2012
    99
    i sell these bulbs guys, check my thread on CDUK
    theyre 3x brighter then Halogen
    http://www.ukcorsa-d.com/forum/showt...esistor-Blocks
    when theyre in the light they look like silvatechs also as theyre silver and not cheap bulbs
    all indicators are CREE bulbs, not cheap SMD's.
    thanks
    http://youtu.be/j3DYsyfS0rM
    27th March 2012
    99
    i also supply fitting around west midlands and around leicester
    15th May 2012
    2,019
    Quote Originally Posted by Jamezz View Post
    thanks
    Can't follow the link mate as I'm not a member - can u copy it over here ?
    VXR Sold
    Porsche Sold
    Hello Cupra
    27th March 2012
    99
    Keep Your Car Safe | New For February 2013 | Rear LED Indicator Bulb Kit
    http://keepyourcarsafe.co.uk/
    Here at Keep Your Car Safe, we've got a new product, exclusive for CD UK!
    Rear LED Indicator Kit, which has;
    2x rear LED indicators
    2x block resistors
    6 scotch locks (4 needed for install, 2 spares)
    All delivered to your door for just £26.87!
    These are the best and brightest LED bulbs on the market, approximately 3 times brighter than the normal halogen bulbs.
    This kit comes with a 2 year warranty on parts, and if you get it supplied from Keep Your Car Safe, we'll also warranty the fitting for 2 years as well!
    Retain the OEM appearance of the rear lights instead of the aftermarket LED light clusters.
    We will be taking group buys for these kits - 10 people at a time.
