Results 1 to 10 of 18
    27th March 2012
    99
    Default NEW: LED Lighting: Canbus-Safe Indicators
    Keep Your Car Safe | New For April 2013 | Rear LED Indicator Bulb Kit
    Here at Keep Your Car Safe, we've got a new product, exclusive for VXRO!
    Rear LED Indicator Kit, which has;
    2x rear LED indicators
    2x block resistors
    6 scotch locks (4 needed for install, 2 spares)
    All delivered to your door 1st Class for just £27.50
    *SPECIAL OFFER*
    Buy Front + Back set of indicators and get Ambur LED side repeaters for FREE All for £55 Delivered!
    These are the best and brightest LED bulbs on the market, approximately 3 times brighter than the normal halogen bulbs.
    This kit comes with a 2 year warranty on parts, and if you get it supplied from Keep Your Car Safe, we'll also warranty the fitting for 2 years as well!
    Retain the OEM appearance of the rear lights instead of the aftermarket LED light clusters.
    http://keepyourcarsafe.co.uk/
    https://www.facebook.com/KeepYourCarSafe?fref=ts
    We will be taking group buys for these kits - 5 people at a time
    VXR enough MurrayVXR's Avatar
    17th July 2012
    1,700
    Easy to install for a Astra VXR?
    27th March 2012
    99
    are astra VXR's offset also?
    if the cluster of the rear light is easy to get out and the harness is accessible then yes very easy, less than a 10min job in the corsa!
    17th July 2012
    1,700
    Not sure to be honest
    27th March 2012
    99
    aslong as the bulb fitament is the same im sure they will fit mate as its not a hard install
    thanks.
    VXRacing ahead Cr416's Avatar
    26th February 2012
    747
    If these fit the astra then I will be ordering a set, LED indicators and lights look well smart.
    Do you do anything like this for the rear left and right tail/brake lights?
    - Astra VXRacing No. 515 311bhp/341ft/lb (97 RON) -
    Fitted: Courtney Stage 3+, Forged, K06, Recirc/Actuator, Klasen Mani, Airtec FMIC, Decat Remus, Direct Route/Pipercross, Mtech clutch & SMF, RARB, DAP's, Ksports, Hekos, Bilstein B8's, LSD.
    To Come: Gauges
    27th March 2012
    99
    Quote Originally Posted by Cr416 View Post
    hi there. sorry about the very late reply, ive currently been really busy with work etc, im sure these will fit astra as theyre same size as the corsa bulbs.
    NEW bulbs will be coming very soon
    everything will be updated in june when new stock will be coming in
    sorry for any inconvenience caused
    VXR enough matthewt23's Avatar
    6th March 2012
    4,317
    Put my name down for some of these!
    VXR enough Cabbage's Avatar
    15th May 2012
    2,019
    Any pics fitted mate ?
    VXR Sold
    Porsche Sold
    Hello Cupra
    26th February 2012
    747
    Quote Originally Posted by Jamezz View Post
    Il double check and will be ordering a set. Would love these on the front and rear brake/tail lights too
    To Come: Gauges
