Results 1 to 4 of 4
Thread: Air Filters
    14th October 2009
    22
    Default Air Filters
    I'm sure this has been asked before, but I can't find it!
    My R8 has the Walkinshaw exhaust - great bit of kit. I've recently had a K&N air filter fitted however, ever since, the car has been noticeably quieter with far less pops and bangs - this is not good, and not what I had anticipated!
    Can anyone advise of a more suitable air filter - or is it just a coincidence!?!?
    VXRacing ahead mik_ok's Avatar
    25th November 2011
    687
    Doesn't make much sense.
    Under load it should flow better than standard, so should not be quieter.
    Under over-run, the throttle is closed, so there is barely any air flowing through the filter.
    14th October 2009
    22
    Oh, ok Mik - it certainly does pull cleaner and better - I'm just not sure why suddenly so quieter when lifting off! Just an oddity maybe!?!?!
    13th July 2009
    47,885
    Change the K&N or a BMC filter, Walkinshaws sell them also.
