Results 1 to 9 of 9
    VXRed durno69's Avatar
    20th October 2012
    81
    Default intercooler remap
    want to get a bigger intercooler to keep the engine cool but do i need a remap dont want the corsa to blow up?
    VXR Torque of the Devil iDan x's Avatar
    26th May 2010
    5,605
    No you don't
    M135i
    VXR Torque of the Devil Grey's Avatar
    19th July 2010
    7,103
    Quote Originally Posted by iDan x View Post
    No you don't
    and doesnt really keep it cool more like intake temps are better but dont benefit from it without map...
    Clique No.10
    20th October 2012
    81
    i would remap it but dont want to risk the 4th piston
    Load of Baubles... randomgary's Avatar
    23rd September 2007
    17,160
    It won't necessitate keep the engine cool. It's all about consistant low intake temps. And no remap needed, car will run as it does in winter with minimal change to the drive.
    6th February 2008
    15,893
    You do not require a remap, but to get the full benefits it does require a remap
    VXR Nothing comes close James H-S's Avatar
    14th February 2011
    12,706
    Quote Originally Posted by durno69 View Post
    Why install an intercooler then?
    Red Corsa VXR Gone! # BMW 118D arrived
    6th February 2008
    15,893
    P4, have gone on std cars
    27th August 2012
    385
    I’d say it’s a worthwhile mod to do on its own as the standard intercooler isn’t that brilliant and the charge temperatures over ambient can often be fairly high. Something which an aftermarket cooler helps keep under control.
    Obviously a remap would get the best out of it but that can be said for any bolt on mod you do e.g. a full exhaust system.
    I wouldn’t let the P4 issue put me off tuning my burg once the warranty is up. It’s more thermal shock that causes it so look after your car, keep it well serviced and make sure it’s warmed up and cooled down properly and it shouldn’t give issues. But if it’s going to go then it’s going to go there isn’t much you can do and as said standard ones have failed too.
    Now vRS powered... Dirty Derv
