Results 1 to 10 of 10
    VXRed Dknights's Avatar
    5th November 2013
    142
    Default Whining Noise !!
    I have a whining noise whilst driving !
    Its coming from the front left of the car when inside driving, the noise speeds up and slows down as I do and it still happens when I release the clutch. The gear box feels fine and the gear stick don't move when accelerating.
    Also when I first pull off and change up into 2nd then accelerate I hear a click from some where near the clutch pedal.
    Could this be the dreaded M32 gear box going on me ?
    Regional Assistant - Scotland West f1slikki's Avatar
    20th May 2009
    1,486
    It does sound like the bearings are failing mate,I had no movement in the gearstick either when my box was knackered.best to get it checked out.on the plus side the clicking sound you hear when setting of 1st into 2nd will be the abs doing a self check and is perfectly normal.
    Arden Astra H VXR/Stage 2/6k Afl's/19"Gloss Black Alloys/Powerfold Mirrors/Sight & Light Pack/Parking Sensors/Keyless Entry,Start/Full Remus&Oil Restrictor Bolt By Jigger/Blue,Red SMD By Stampede/Drilled & Grooved Discs/Tints/Green Cotton Filter/Carbon Iinlays/VXR Grill Badge/Private 3D Gel Carbon Plate/Team Hekos/Stubby Bmw Ariel/Debadged//Indicator Surrounds/C,C Bootstrip/Led Side & Plate Lights/VXRO Stickers/
    5th November 2013
    142
    Thanks mate, I'm new to the VXR scene only had the car a week. On the other plus side I have a network q warranty
    20th May 2009
    1,486
    No probs mate,thats good u got warranty.
    VXRacing ahead Tomwarren1992's Avatar
    6th April 2012
    524
    Quote Originally Posted by Dknights View Post
    Dont wanna scaremonger but warranty might not cover it.. Get it checked soon as
    5th November 2013
    142
    Hope it does, only had it a week and noticed the noise on the test drive and the salesman said he was told it goes when it's warmed up but I didn't know about them going wrong then
    20th May 2009
    1,486
    No it doesn't go away when warm,typical salesman tell you any old pish to get the sale, I hope your covered under warranty mate,but if your not there's 2 places that specialise in the m32 bearing repairs.will cost around £400 -£500 for a full refurb.
    VXRed mattleese's Avatar
    20th April 2013
    185
    I had this also, was gutted as it was suggested it was the gearbox, turned out to be the driver side wheel bearing :-) cheap at easy fix!
    17,596
    You sure its not just your bird in the passenger seat?
    5th November 2013
    142
    Yeah tired that kicked her out and it's still there 😄
