Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
    4th October 2013
    108
    Default Forged Regal Rebuild
    Engine died 4 times in a row from cold, So I did a compression test last week and found a P4 with only 70psi, and a loud tappet knocking which has been irritating me for a while!
    Time to go for Forged internals ready for future tuning.
    Need the job doing asap so it's off to Regal on saturday to drop the car off.
    I've requested some before and after pics of the engine so I will post these up once I get the car back and share the results of the build (No remap just rebuild for now!)
    componenets being put in:
    RSS High comp pistons
    RSS Forged steel rods
    RSS bearing shells
    piston rings set
    vxr atheena head gasket
    ARP Head stud conversion
    valve stem seals
    valve recut, tappet reshimming & decoke head
    and an AC delete as i'm not paying to fix that
    2nd January 2014
    72
    Hi if you don't mind me asking how much did it set you back. Want to do the same.
    Sent from my GT-I9505 using Tapatalk
    4th October 2013
    108
    including the oil, antifreeze, labour, cambelt kit, waterpump, running the car in with a further oil & oil filter change just over 3K
    VXR Torque of the Devil jkemish's Avatar
    21st November 2013
    5,017
    Quote Originally Posted by bugz87 View Post
    Wow, you saved up for it I guess
    Astra VXR Time Attack Build
    Follow me on Facebook at JK Motorsport
    https://www.facebook.com/JK-Motorspo...7132121985280/
    2nd January 2014
    72
    Thats not bad at all. After all that work it should be pretty much bullet proof.
    21st November 2013
    5,017
    Quote Originally Posted by ArcticArran View Post
    You would like to think mate
    It's an orange thing! craigyvxr's Avatar
    17th April 2007
    3,532
    If there was a noisy tappet did you not think about checkin the tappet to see if it was stuck and holding the valve open?
    236BHP 260lb/ft
    Green Hell Club
    Team Oldskool - Bring back the good old days!!!
    VXR Nothing comes close James H-S's Avatar
    14th February 2011
    12,706
    Did you not consider warreng? He does a drive in drive out service for like £1500 for a forged engine
    Red Corsa VXR Gone! # BMW 118D arrived
    17th November 2011
    1,863
    Quote Originally Posted by James H-S View Post
    +1 could have saved yourself about £1000 going to Warren for a High Comp Forge Build
    Corsa VXR
    Focus RS
    4th October 2013
    108
    I did, but he's got a lot of work on at the mo and I need the job done quick
