Results 1 to 5 of 5
    24th April 2010
    212
    Default Possible to fit AFL lights...straight swap?
    Hi all,
    I've been pondering about getting some adaptive forward lights but is it a straight swap?
    Has anyone fitted some before?
    Cheers,
    Paul
    19th January 2011
    326
    If you havent got AFL's already fitted then no it wont be a straight swap.
    If you want them to turn as you go round corners it takes a abit of work.
    see this link to pecky's website that has a step by step guide of how to do it. Pecky does an adaptive harness that eliminates you having to cut and earth the original headlight ballast which are £40.00 for the 2. Or if your confident you could rewire them yourself.
    https://www.diagnostics.org.uk/2010/...-headlights-2/
    If you want just normal xenons that look like afls just dont turn round corners then look in the group buy thread on here.
    http://www.vxronline.co.uk/forum/sho...enon-Headlamps
    Astra Nurburgring Edition 248 (Written off )
    Ford Focus RS MK2 (Wasnt as fun)
    Back in - Astra Nurburgring Edition 225
    24th April 2010
    212
    Thanks Marc, I took a look at the link and it looks like quite a bit of work. I don't think I'll bother with it tbh.
    Must save the pennies and get an J!
    Cheers,
    Paul
    19th January 2011
    326
    Like I said if you've have a look at the other link. There the same as afls just don't go round corners.
    There just plug and play straight fit. No faffing around like trying to fit afls.
    VXR Torque of the Devil vxrtricky's Avatar
    17th April 2008
    5,166
    they are expensive to retro fit and takes some work collecting all the parts. or expensive if u buy a complete set
