Regal Autosport is proud to announce the partnership with KW Automotives new brand, ST Suspension, new for 2014….ST Suspension offers maximum performance for fast-road use and perfect style. Made in Germany by KW, the ST suspensions suspensions program combines leading KW technology for the road with the best price-performance ratio. With German TUV certificate.
Whether you are looking for spacers and springs for the perfect look or would like to install a coilover suspension for added performance or to pinpoint that perfect ride height, we’ve teamed up with ST suspensions to offer many different solutions with excellent quality.
The ST Suspensions range boasts race-winning technology, expertly re-engineered for the road. The ST Suspensions product range is enormous, so for today… Let’s Talk ST Coilover Suspension for your Vauxhall…
ST X Coilovers
Fixed Damper Setting
Need to get low? ST coilovers enable on-car ride height adjustment from moderate to
eXtreme. Each kit is designed and manufactured using KW automotive’s expertise. The result is a high quality product that delivers fantastic driving dynamics.
ST X coilovers have a fixed damping rate for fast road use and deliver sporty handling by reducing the car’s body roll during compression. The high-quality ST X coilover kit includes a low-friction and pressure resistant housing alongside a chrome-plated piston rod for maximum longevity.
  • Individual lowering within the T‹V-tested adjustment range
  • Front and rear axle ride height adjustment (when possible)
  • Galvanized Coilover struts
  • Complete solution with adjustable spring plate, race
  • Spring system and bump stops with dust protection
  • Twin-tube dampers with high-quality components for maximum longevity
We're also offering 12% off ST Suspension as an introductory offer, see below for VXR applications...
Corsa VXR - http://regal-auto.co.uk/shop/st-susp...xr-p-1144.html
Astra VXR - http://regal-auto.co.uk/shop/st-susp...xr-p-1134.html
Merivia VXR - http://regal-auto.co.uk/shop/index.p...+st+suspension
