Results 1 to 7 of 7
    VXRed kevjacques's Avatar
    31st October 2012
    36
    Default Reverse camera 4 pin connector
    Received reverse camera for vxmmi today and is powered direct from the head unit with a 4 pin connector rather than wiring it to the reverse lights as I was led to believe....great stuff! Downside is I didn't think I'd have to remove the bumper! Lol! Doing this tomorrow when I have the correct tools.
    1.8 Twintop Design Power Red
    VXR Front Lower Spoiler / Reat Skirt / Side Skirts / Rear Spoiler / 18" Rims /
    VXMMI, Boomerang Armrest, VXR Pedals, Power Fold Mirrors
    VXR enough Arctic martin's Avatar
    27th December 2012
    4,278
    Why you gonna remove the bumper?
    WG Motorworks Fully forged Astra Vxr Arctic ...
    Rabbid tuned... TD Stage 3 hybrid, Piper valve springs, piper cams, klasen inlet manifold, Courtney cdti conversion, Airtec front mount intercooler, 3" scorpion exhaust, Turbosmart actuator, Forge recirc valve, Quaife LSD, Helix Clutch & SMF, Rear anti roll bar, blue & red SMD conversion , bi xenons and CD70
    31st October 2012
    36
    Unable to get wires through the body of the car. The twin top is apparently different to the hatch, and more difficult!
    27th December 2012
    4,278
    Try pulling the plastic up on the inside of the boot and take you number plate bulb holders out and look through you'll see some rubber vent like thing with flaps get a thin bamboo stick tape the camera wires to it and poke it through the number plate light hole through the rubber and you'll be able to grab the stick from inside the boot and pull it through. Then just run it down side of car to stereo
    31st October 2012
    36
    Will look again tomorrow. Think I know what you mean - although the twintop doesn't seem to have vents. Saw something similar on YouTube. Have you done this to a twintop?
    27th December 2012
    4,278
    No but it should still have vents most cars do
    31st October 2012
    36
    Sorted it this morning feeding it through a hole behind the rear light cluster and down behind the bumper
