Results 1 to 6 of 6
    20th November 2013
    33
    Default Corsa losing boost?
    Recently had my car mapped and its boosting 1.3 bar, it use to hold boost okay now its only a split second then dipped to just under 1 bar and is making a whistling noise there is no leaks in the boost pipes or anywere just wondering what it could be actuator is standard thinking it could be that just wanna check before i spend £170 on it! Thanks!
    VXRacing ahead xsketchx's Avatar
    21st December 2013
    577
    Mines standard though didn't read yours was mapped!
    Don't know what it is in bar or weather mines okay or not but boosts up to 16psi and holds for a split second before dropping down to 10psi under acceleration rising again after 5000rpm up to 12psi
    VXR enough Stigy's Avatar
    7th September 2013
    1,202
    That just sounds like overboost? It goes up for like 5 seconds in 3rd upwards. Helps with overtaking.
    Someone who knows more will be along eventually.
    I'm glad I'm not judgemental like all of you smug, superficial idiots.
    21st December 2013
    577
    Quote Originally Posted by Stigy View Post
    Didn't think the car had an overboost if it's been mapped?
    VXRacing ahead Tom{BSc}'s Avatar
    29th January 2011
    585
    Take it back to the person who mapped it?
    12th April 2009
    20,128
    Quote Originally Posted by Tom{BSc} View Post
    Amen to this!
    Sent from my Nokia 3210 via tapatalk
    Opel Nürburgring Edition No.534 / PSN - ItzMrGoodKat / IG - ItzMrGoodKat
