Page 15 of 16 FirstFirst ... 5 13 14 15 16 LastLast
Results 141 to 150 of 152
  1. #141
    24th October 2009
    115
    hi adam
    just doing the mod at the moment, i was a bit worried about doing it myself but Woody is able to guide you through all of the set up etc, i took the easy way out and got Woody to supply the cables and sort the wiring for me, just waiting for the loom to come back and then will be fitting, once mine is up and running will let you know, but Woody is always on hand to guide you through the process.
    Ivan
  2. #142
    24th October 2009
    115
    hi all
    just to say that the reversing camera works a treat and is a great mod, i had a friend of woodys sort the the wiring for me so it practably become plug and play, Woody also gives a lot of support if needed.
    a great mod
    Ivan
  3. #143
    VXR enough Woody's Avatar
    16th December 2013
    2,007
    Pics "needed" Ivan or some might be thinking that it never happened
    Woody's Vx Ice Addons
  4. #144
    16th December 2013
    2,007
    Default Buybacks
    A quick reminder to any existing customer who is "moving on" from their Vectra-C / Astra-H / Signum or Zafira-B and who has some of the equipment I sell ... I also offer a "buyback" service
    No, this is NOT at your original "Cost Price" however, my offer is likely to be amongst the best you will receive on the "2nd hand" market
    Any such units will be re-offered for sale on the relevant forums at an attractive price to new users, and of course, with the latest software programmed in with lifetime free updates.
    So, before you cut your losses, and sell too cheaply, give me a call, email, or PM. You may well be pleasantly surprised
    Woody
  5. #145
    VXR enough Matt1982's Avatar
    19th June 2016
    1,365
    What can I gain from fitting one to my Astra with cd30 mp3/aux and gid screen??
    Cheers Matt
  6. #146
    16th December 2013
    2,007
    Hi @Matt1982
    Have you looked at the youtube videos in Post #1 or downloaded any of the PDF files linked to also in Post#1 ?
    Here are a couple of the PDF links, but look at the videos for more info
    Main CU - http://www.pepas.cz/wp-content/uploa...CU-01_LAST.pdf
    CU in a Vxr - http://www.pepas.cz/wp-content/uploa...on_ParList.pdf
    HTH
  7. #147
    16th December 2013
    2,007
    Stock
    PepaS has been out of stock of these modules for over a month now while new stock is manufactured.
    The good news is that I have now received a small consignment of new stock.
    Woody
    12/5/2018 - Update
    Selling out fast now
    Only 1 Comfort Unit and 1 VCU-01 Video Module with CAM-PS left now
  8. #148
    VXRacing ahead BigDov's Avatar
    8th February 2014
    642
    Quick question, can codes be cleared with this plugged in, only asking as got a 2.8t signum with double decats so naturally the EML periodically comes up for low voltage at the 2nd sensor, and would save having to rip the ashtray and what not out to remove the CU and plug the code reader in to clear the code when it pops up?
    MK5 VXR - Piper Turbo Back - Bilstien B8 Shocks - Eibach Sportlines - Whiteline RARB - Forge Re-circ( Yellow spring) - CDti intake - Direct feed hose Kit - Forge FMIC - Forge Actuator( Red Spring) - ANSU Fuel Pump - RnD stage 3 remap.
  9. #149
    16th December 2013
    2,007
    Quote Originally Posted by BigDov View Post
    Quick answer
    You can run a OBD splitter cable (I don't have any in stock) provided it is fully wired pin for pin (most are only partial, mine were a special order when I had them).
    Otherwise you need to unplug the CU to allow the Tech2 / Op Com unit to be attached.
    You would have needed to disconnect the CU in any event prior to attempting any re-programming even with a splitter cable.
    HTH
    Woody
    PS - Even if you disconnect a CU for diag reasons, re-fitting is pretty much automatic afterwards.
  10. #150
    VXR enough Rapid's Avatar
    25th October 2012
    1,537
    I would highly recommend Woody and his installations to anyone looking to "upgrade" their cars for Diag & the CU + VCU's. I've purchased a VCU-02 and currently installing it into my car (Meriva VXR), along with the rear view camera and Raspberry Pi.
    Woody has always been at the end of a phone call and helped out immensely, hes called me and taken time out of his day to go through the bits and pieces needed and even looked up parts for me too. I got stuck with splitting the RGB cable but his good friend Peter was there to help with splitting the cable for the VCU, I sent it off to him and within a couple of days he sent it back all done, very professionally. Again, I got stuck with the "TAIL's-SET" that Woody supplies and have sent an extension Fakra loom and the TAIL's-SET to another friend of Woodys, Dean. I'm just awaiting this back to continue to with my installation.
    Woody has been excellent and I'm glad hes been here to help and especaially with everything hes done for me
    Thanks Again Woody (Y)
    MERIVA VXR
