Page 3 of 23 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 228
  1. #21
    VXR enough Craig 522's Avatar
    12th February 2013
    2,160
    Quote Originally Posted by Hotraph View Post
    Did you get the other blue pipe with the dump valve and the T piece?
    You mean vac pipe buddy? I've got vac pipe but it's purple, probably got a T piece somewhere? Why you ask?
  2. #22
    VXRacing ahead Hotraph's Avatar
    28th March 2013
    636
    Ahh right . Yeah vac pipe thats it. Just curious bud.
    Have fun fitting it.
    I really struggled to get the original throttle body pipe off with the lower clip.
    But looks like you have had that off so should be all good.
  3. #23
    VXRacing ahead tcd_burg's Avatar
    27th March 2010
    604
    Car is looking great well done
  4. #24
    12th February 2013
    2,160
    Quote Originally Posted by tcd_burg View Post
    Cheers buddy. Will be updating thread later so can get some more up to date pics ;-)
  5. #25
    12th February 2013
    2,160
    Right I need to pull my finger our and catch up with my thread, have a lot of worked being done in 4 weeks so would like to get the thread up to date for then 😉
    limited edition 1 of 2 😜
  6. #26
    12th February 2013
    2,160
    When it was in for a service and a new coil pack I changed to a greddy magnetic sump plug. Went with purple but doesn't matter as it's not seen ☺
    (Didn't take a pic of this)
  7. #27
    12th February 2013
    2,160
    Next thing that took my eye was the bonnet piston that a member off here use to get, I don't know why these were not put on as standard. I've had to screen shot this off someone's build thread so thank you ☺ mines been airbrushed and will get to that later
  8. #28
    12th February 2013
    2,160
    I'd had a Mtec short shifter for a while by now (not fitted) and finally got around to fitting it. Well attempting to fit it, we could not get the cap off no matter how hard or what we tried, I decided to put the battery tray back on etc and to give it a little WD over a couple of weeks to help it loose, we decided to make the most of the day and do somthing else.......
    We smoothed the roof as I never listen to the radio, I never planned on doing a build thread and now regret not taking pics as we went along. I really do like the results of this😉
  9. #29
    12th February 2013
    2,160
    Next was a long awaited trip to Warren and Rabbid 😉. Was in for injectors and a map, went for 613cc porsche injectors otherwise I'd need to upgrade them again in the future ☺
    While I was there Warren had a delivery of poweflex engine mounts, so thought it'd be rude not to ☺
  10. #30
    12th February 2013
    2,160
    Obviously I couldn't of travelled all the way to Warrens without the "compulsory" stickers.
    The car was completely different on the way home, had a bit of a play with a miserable bloke in a audi😉. Hate it when someone flashes there lights at you when they want to get by. Even though your exceeding the speed limit (just a little tho!&#128540
