Results 1 to 10 of 10
    30th March 2014
    45
    Default fitting intercooler, will i need a remap
    hi all. my cars running a stage 2 atm. spotted a good price on an intercooler so im wondering if i was to fit it would i need another remap to get the benefit from it? also if i fittee it would it cause the car to run lean
    VXR Torque of the Devil vxrtricky's Avatar
    17th April 2008
    5,173
    you should run fine but will need a
    tweak to your map to make the most of it.
    what cooler you gone for?
    30th March 2014
    45
    its a tx autosport with the top hat pipe
    19th May 2014
    1,356
    Ull be fine to run it without a remap
    30th March 2014
    45
    cheers for the info
    19th May 2014
    1,356
    What other mods u got. I would get as much as you can before remapping as u won't damage anything driving with ur upgraded intercooler and exhuast ect but ur gains will be through mapping.
    12th April 2009
    19,960
    Quote Originally Posted by Jamiearmstrongvxr View Post
    +1
    Astra Nürburgring Edition No.534
    30th March 2014
    45
    iv got a full cobrasport turboback, uprated bov, pipercross intake and a stage 2 remap so an intercoolers the last mod i will be doing
    Regional Assistant - South Essex nurburgring24's Avatar
    13th September 2008
    19,837
    the car will adjust to the cooler
    19th May 2014
    1,356
    If it's ur last mod then a suppose u could go for a stage 3 remap then bit there is no rush to do that all depends if u want to go more
