Results 1 to 3 of 3
    VXRed joey5847's Avatar
    17th June 2014
    41
    Thumbs down #urgent# need help with boost issue
    my car is holding the boost but it wont go above 1.0Bar its stage 3 tuned but no making the HP due to this issue, had SM tuning around today he could not make heads or tails of this issue either and because of it he postponed my map...
    actuator in working order
    recirculation vale working
    no boost leaks
    solenoid works
    any ideas ?
    cheers
    VXR enough Ant21's Avatar
    29th September 2013
    1,386
    I'd hazard a guess and say the actuator isn't set up properly and is opening the bypass early.
    17th June 2014
    41
    SM tuning was here trouble shooting it but he couldnt make heads or tails of it and he set it up, and adjusted it still no joy
