Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: Front Camber
    VXRacing ahead spartan35025's Avatar
    17th March 2011
    523
    Default Front Camber
    I'm interested to know what camber people are running once you have lowered the suspension. I understand that lowering has the effect of adding negative camber, but I'm not sure how much is best for fast road use (although it is subjective).
    I started off with -0°30' when aligned after fitting my DAP springs. Later on I had camber bolts added and increased this to -1°30. I didn't notice any uneven tyre wear and I felt as though it did corner better. However I've also swapped from 19" to 18" wheels and had new tyres in between, so it's hard to accurately judge. Most recently I pushed this to -2°00' but it feels as thought the wheels initially turn in quickly but then lurch from gripping to understeer when you corner hard. I also can't feel the slip diff engaging as much as it used to.
    I'm going to have the camber backed off a little, but I can't decide how far to go. I have searched for this subject on here and AON, but very few people list specific settings. For info, my toe and caster setting are un-alerted (front & rear). Any advice would be appreciated.
    Cheers,
    Mike
    [FONT="Tahoma"]Arden Blue Astra : Gone
    Parts for sale
    VXR enough CorsaVX-R114's Avatar
    15th February 2010
    4,637
    I run half a degree of toe and 1.5 camber, I run 17's and that's pretty perfect for me, on the road.
    17th March 2011
    523
    Quote Originally Posted by CorsaVX-R114 View Post
    Cheers for the reply. I hadn't thought about changing the toe angle.
    Did you get the toe set at the same time as the camber? Did you noticed any change in the stability at speed?
    Parts for sale
    15th February 2010
    4,637
    Yes it was all set at the same time. No compromise in stability as I've noticed, in cornering or straights. I've done over 160mph on satnav speedo and she felt solid
    17th March 2011
    523
    Sounds good. Even at 70mph, with this level of camber mine feels twitchy. Its a shame you didn't have the two done at separate times to know which adjustment made the most difference, but its understandable as it costs every time you want to try a change! I'll have to pay to get my camber put back, but as the toe was recently corrected back to 0°, I might leave that alone till next time and save myself the £30.
    Parts for sale
    The Red Baron... Deathace's Avatar
    25th May 2011
    6,964
    For my 19" OEM's on daps (oem shocks) I didn't need to change anything as it seemed to be ok (when checked) but having recently changed to KW's I can feel the tracking is out from the car wanting to wander to the right but the company I will be taking it to will sort out 4 wheel alignment with bolts and shims where needed, will let you know the figures when it is done if it helps but I am still on 19" with the BBS'.
    Russ
    VXRed slonik's Avatar
    12th December 2013
    169
    spartan35025
    do you use car on track days or only everyday driving?
    17th March 2011
    523
    Quote Originally Posted by Deathace View Post
    Russ
    Thanks Russ, it would be interesting to have a read of the figures once you get sorted. I didn't have any problems with my alignment, just fancied having a little play around with my camber settings to see if a little more negative caber would improve the traction through tight corners. However as above, I found that -2°00' makes the car a bit twitchy at speed and seems to loose traction on tight corners.
    Quote Originally Posted by slonik View Post
    spartan35025
    Its used as a daily driver, so I'm trying to get the best 'fast road' setup without making it unstable in a straight line or effecting tyre wear too badly (a little is acceptable).
    Cheers,
    Mike
    Parts for sale
    15th February 2010
    4,637
    I've just taken off my wheels with federal RSR's off and after 4k of hard millage they are bald, you can barely notice there's been any camber wear on the tyres
    12th December 2013
    169
    1.5 camber not so much, but half degree toe... may be you are wrong? check it again.
    with half degree toe your tyres will wear very fast.
    i usually make 0.1-0.2 toe out.
