Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: Front Camber
  1. #21
    The Red Baron... Deathace's Avatar
    25th May 2011
    6,881
    Auto test in Norwich mate 4 meteor close round back of the airport.
    Russ
    Sent via carrier pigeon with SlappaTorque
  2. #22
    VXRed blooded grantvxr's Avatar
    20th December 2013
    325
    ah awesome only 20 minutes away how much do they charge?
  3. #23
    25th May 2011
    6,881
    £48 for front only and £78 for front and rear.
    Russ
  4. #24
    20th December 2013
    325
    Had mine done today. Slightly confused with what's going on with the rears.
    They haven't touched the rears yet they have changed on the before and after?
  5. #25
    20th December 2013
    325
    Also the castor bushes don't appear to do a lot!!!! My castor is the same as barons! Or do you have castor bushes?
  6. #26
    24th January 2010
    403
    Looking at having my front wheels aligned as i noticed when changing tyres round that i had alot of inside wear of about an inch and half from inside of tyre...im just wondering can they adjust it as it is or do i need camber bolts?
    Courts stage 2..3" full scorpion non res exhaust..lowered on eibach prolines
  7. #27
    4th October 2014
    349
    Good question lee
  8. #28
    25th May 2011
    6,881
    Grant: the rears will have moved when they jack the front up to adjust the camber, the castor is not affected on astras so just toe and camber on the front.
    Lee: Contact some companies that have the hunter system to see if they provide bolts if needed, if they do happy days if not just buy a set of Eibach or Powerflex bolts and if you need them fit them if not sell them on.
    Russ
