Results 1 to 10 of 10
    VXRed Shivvo's Avatar
    1st November 2014
    12
    Default Fitting lowering springs
    Anyone done it theirselves? Thinkin of having a bash but front assembly looks a tad complicated and don't want to **** anything up. Any help would be appreciated or a how to even better 😎 Cheers, Shivvo
    19th May 2014
    1,356
    Haven't worked on an astra j bt can't see it being difficult
    VXR enough Bailsey's Avatar
    19th December 2013
    1,385
    If heard the hubs are a pain in the **** and there's sensors on the vehicle for suspension/damper adjusting easier to get a garage to do it 😜 I am
    Sent from my iPad using Tapatalk HD
    1st November 2014
    12
    Quote Originally Posted by Bailsey View Post
    Yea looks a right pain, never seen a front assembly like it. It's like a damn range rover ��
    17th February 2013
    183
    Yeah i done mine with my grandad and hes was a mechanic all his life and said hes never seen anything like it! Took an 2 hours to work out how to do it then it took half hour or so to do the other one but the was alot of unbolting parts dropped the hub and was having to put a bit of stress on drive train! My advice if you dont have a mechanic on hand to help or all the different tools take it to a garage far more easy and less stressful!
    Arden GTC VXR
    Aero Pack, Premium Forward Lighting, Full Leathers
    http://www.vxronline.co.uk/forum/sho...-Arden-GTC-VXR
    9th August 2011
    2,394
    did a mates last year , i had a 2 poster to use which made it much easier but the hubs are heavy so care needs to be taken , the coupling for the electronics is a bit different too , its a twist lock arrangement , so dont be ruff with it ! to sum up , thorough recce and you'll do it easy enough as a DIYer
    3rd November 2014
    35
    Hi all I'm new to this just got myself astra vxr nurburgring wanting to do stage 3 so I fitted Forge actuator and orderd airtec intercooler do I need an inlet manifold thanks
    9th August 2011
    2,394
    all good carl but your rocking a H , this is the J section of the forum pal lol
    3rd November 2014
    35
    Haha yeh ok ya can tell am new lol
    9th August 2011
    2,394
    yep , still wet behind the ears eh kid ? lol
