Results 1 to 6 of 6
    20th May 2014
    27
    Angry Corsa VXR Fault Code 2261
    Hi guys,
    Not long ago i put a K n N air filter on my car. A few days in it started making a loud chattering noise instead of the 'tssss' it had before. I took it off and a few days from then a fault came up (code:2261). It says recirculating solenoid valve or something. The car still makes a very faint chatter when changing gear. The fault light comes on and off and it does feel like the turbo hits in alot harder when the light is off. Does anybody know what this could be or has anyone else had this problem too? Any help would be great thanks!!!
    VXRed vxrburnsrubber's Avatar
    7th April 2014
    236
    sounds like there is a problem with the recirc valve.
    the only reason the turbo would chatter is due to the high pressure trying to release air back through the turbo onto the fins/blades because the valve isn't releasing.
    maybe worth checking the recirc valve and vacuum line's.
    2014 Corsa VXR, Remus 3 Piece, Courtenay Cold Air Feed With K&N Panel Filter
    O)))..........VXRBURNSRUBBER..........(((O
    VXR enough corsa-del68's Avatar
    18th February 2011
    3,346
    Quote Originally Posted by vxrburnsrubber View Post
    + 1
    black sapphire corsa vxr stage 3 241.7 bhp & 250 lb torque 3 piece remus..30/20 P.I lowering springs. vxr badge front and rear. blue smd conversion..insignia washer jets...18" diamond cut alloys...pipercross cone...forge brace bar...de-badged...smoked side repeaters..airtec intercooler,forge recirc valve,cool runnin stat,390cc injectors,courteney fuel pump and full courteney hose kit..mtech short shifter
    20th May 2014
    27
    Default Hmm
    My mate who is a mechanic has checked the valve and the pipes and they are all good. He thinks something on/in the turbo may have a crack
    7th April 2014
    236
    maybe worth removing the recirc valve and check for any blockage or seizure.
    the sign's your telling us is a common recirc valve failure not releasing air.
    28th June 2014
    75
    Code reads as turbo charger by-pass valve (mechanical)
