Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    VXRed theRoundsta's Avatar
    2nd April 2014
    35
    Exclamation Decat DownPipe Onto Standard CatBack System
    Would the scorpion decat down pipe fit straight onto standard cat back system? Anyone tried it? Link for it is below
    http://www.scorpionexhaust.co.uk/sco...cat-2516-p.asp
    @theRoundsta
    Sean
    16th November 2014
    22
    should do aslong as the diameter of the exhaust match
    15th May 2013
    17,324
    Default Decat DownPipe Onto Standard CatBack System
    Removed...
    VXR enough Bailsey's Avatar
    19th December 2013
    1,385
    I have the full scorpion sports cat non res system going to decat soon and I don't think it will as its a 76mm 3 inch system if the standard system is same diameter which I don't have think it is then it won't fit without problems
    3rd March 2013
    1,357
    Ive got Cobra's decat down pipe and 2nd cat on the rest of the standard system. AFAIK the standard system is 2.75" so not much difference ....
    Summit White GTC - GONE
    Replaced by Mk7 5dr Golf R
    My Progress Thread
    2nd April 2014
    35
    I see. I've question it with scorpion; waiting for an answer. If not I'll have to get the full system.
    @theRoundsta
    Sean
    2nd April 2014
    35
    What do you think of the sound pal?
    @theRoundsta
    Sean
    2nd April 2014
    35
    Quote Originally Posted by Bailsey View Post
    @theRoundsta
    Sean
    3rd March 2013
    1,357
    Quote Originally Posted by theRoundsta View Post
    Double decat sounds the mutts nuts mate! Not any louder than standard until you put the foot down
    My Progress Thread
    19th December 2013
    1,385
    Once it's worn in it sounds amazing I'm hoping to decat soon but if you go to PVS I'll start it up for you as will be on scorpion stand 😜
