Results 1 to 10 of 15
    VXRed Adingley84's Avatar
    14th December 2014
    89
    Default Mods without remap - is it ok?
    I currently own a Subaru Forester 2.5XT (230bhp) and am looking to buy an Astra Vxr in the new year. (No longer need all that practicality although love the sleeper appeal!)
    Subaru boxer engines are renowned for needing a remap whenever any breathing/exhaust mods are made but Vxr's seem to be different.
    E.g. Decat downpipe +10/15 bhp straight out the box
    There seem to be quite a few Vxrs with cat back/turbo back and just downpipe mods but not remapped. Are they really running ok or causing long term damage? Are they really pushing out more ponies just because of the parts?
    14th December 2014
    89
    No takers for any info?
    18th February 2007
    51,609
    You can fit the hardware without any remap required
    Astra
    28th June 2011
    2,780
    Some times can crack manifold as I belive that the astra run lean when the come out of the box not sure if I am 100% right on this but I'm sure it's true as I fitted cone and exaughst and what do u know I have cracked manifold
    15th May 2013
    17,909
    I ran mine for a bit without a map when I had a sports cat fitted and then a Milltek to it as well. It will run and there will be some gains but mine ran a bit rich and stank. ever since the map it's been fine.
    So answer is yes, but I'd recommend a map eventually
    As above id either have a cone mapped in or have a CDTi box
    18th February 2007
    51,609
    Cracked manifolds happen - regardless of tune
    Astra
    21st December 2014
    25
    Any type of bolt on should have the software not just for power but to get the best out your bolt ons
    18th February 2007
    51,609
    Quote Originally Posted by stanford View Post
    Disagree, you can see reasonable gains with decent breathing and exhaust softens the flat spot out that they all have - yes if you buy an intercooler then get a map to make the most of it but you can install it and run it with just the hardware installed until you get it mapped if you were saving up or needed to wait.
    Remember that Vauxhall themselves threw the Remus on the Nurburgring - there were no software changes from the std exhaust and every single owner would vouch for improved performance
    Astra
    VXR Torque of the Devil Grey's Avatar
    19th July 2010
    7,103
    Quote Originally Posted by IanJ View Post
    +1
    Clique No.10
    4th October 2014
    349
    You can't put a cracked manifold down to a cone filter nor exhaust system, you can however put it down to thrashing it from cold, due to the amount of hammer it's had etc but mods won't make the slightest difference to it
