Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    VXRed Adingley84's Avatar
    14th December 2014
    89
    Quote Originally Posted by IanJ View Post
    Remember that Vauxhall themselves threw the Remus on the Nurburgring - there were no software changes from the std exhaust and every single owner would vouch for improved performance
    Very good point!
  2. #12
    14th December 2014
    89
    Quote Originally Posted by anthony86 View Post
    You can't put a cracked manifold down to a cone filter nor exhaust system, you can however put it down to thrashing it from cold, due to the amount of hammer it's had etc but mods won't make the slightest difference to it
    Really good to learn about the cracked manifold from everyone here. Time to make my way over to a 'buying guide' type thread to save me scribbling
    Want to check over an potential buy veeeeery closely as i definitely don't want to walk into a big bill!
  3. #13
    VXRed Theunknown's Avatar
    28th November 2013
    75
    You can run without a map, but you won't be taking the full advantage of the new parts. For example if you decat the exhaust the lambda sensor will notice difference and then run the car rich.
    Try to install as much parts as you want, then get a remap.
  4. #14
    VXR enough DRC 72's Avatar
    22nd April 2011
    4,457
    On my corsa VXR i ran a cat back and pre-cat delete pipe on the standard map.
    It put my BHP to 195 but more importantly it put my torque figure to 228 ftlbs.
    Sir Dale Of Yorkshire
  5. #15
    4th October 2014
    349
    Yer that's all well and good but if you have a remap and you get say 215 bhp 230 lbs ft of torque it's a very different power output to what you are now, even if you ran the same figures as you are now on a map itl feel and be better mapped
    Like my is running 265bhp with a full 3" decat system astra vxr, but a mapped 265bhp astra vxr will be a lot more smoother and will pass me, even if we had the same torque
