Results 1 to 4 of 4
    20th May 2014
    27
    Default Interior lighting!
    Ok, so I seen a really cool corsa vxr on here. Every interior light was blue from the dashboard to the window switches. Is this hard to do? Are they just replaceable bulbs or would you need to solder? Does anyone have a tutorial of how they did it? Would be much appreciated 😊
    VXR enough VXR.Tom's Avatar
    29th November 2011
    2,850
    It's an SMD conversion that you would be looking at, as far as I know its a lot of work and lots of soldering.
    Glacier White Nurburgring #298
    VXR enough corsa-del68's Avatar
    18th February 2011
    3,346
    pm stampede on here mate,hes from bradford/halifax area he did mine and hundreds of everybody elses on here....where you based m8
    black sapphire corsa vxr stage 3 241.7 bhp & 250 lb torque 3 piece remus..30/20 P.I lowering springs. vxr badge front and rear. blue smd conversion..insignia washer jets...18" diamond cut alloys...pipercross cone...forge brace bar...de-badged...smoked side repeaters..airtec intercooler,forge recirc valve,cool runnin stat,390cc injectors,courteney fuel pump and full courteney hose kit..mtech short shifter
    20th May 2014
    27
    Hi, ah great thankyou. I live in Corby, Northamptonshire
