Results 1 to 10 of 14
    VXRacing ahead Dirty_badger's Avatar
    27th February 2015
    616
    Post Astra H VXR clutch slip
    Had my car remapped at Courtenay on Wednesday, running a stage 3 map with airtec FMIC and cobra full de-cat exhaust. Ran 290BHP and 344ft/lbs of torque which I was more than happy with.
    After driving the car for a few days I've noticed that the clutch has started slipping, it's only slipping in 4th gear though.
    Just wondering what recommendations anyone has to as which clutch set up I should be looking at upgrading to? The car has done 37k
    VXR enough wellsy_mush's Avatar
    6th August 2010
    1,703
    Back to Courtney then for single mass fly wheel and up rated clutch.
    Sent from my HTC One_M8
    Rabbid Stage 3, Airtech front mount, GM Hids, Cobra Exhaust, Direct route ram air, EBC Disc's, Red stuff pads and Hel brake lines.
    The list goes on
    VXRed K33STH's Avatar
    3rd April 2012
    123
    I had the same problem and was advised that a standard replacement part would be suitable so that's what I got, and haven't had a problem since.
    So unless your going for more power then an original replacement is fine
    27th February 2015
    616
    I've been looking at the uprated clutch cover with OE clutch plate and DMF but I'm unsure what to do. Don't think I'll be tuning any more than stage 3 which clutch is in as standard is it the LUK clutch with LUK flywheel?
    K33STH, how much did you pay for your clutch kit and did you replace the fly wheel at the same time?
    VXR enough Jessy's Avatar
    25th November 2012
    1,828
    If staying stage 3 I'd stick with standard clutch kit and DMF.
    27th February 2015
    616
    Do we know if the standard clutch kit is made by LUK? http://m.ebay.co.uk/itm/110951057096...ATCHING_ACTIVE I've found this one on the good old flea bay
    VXRed Carsevo99's Avatar
    4th June 2012
    194
    On evos I found helix the best as they drive standard but bite so hard changing gear you think a mount has gone awsome clutches mate
    27th February 2015
    616
    Update on the clutch slip. It seems to have stopped now :/ weird I know but took her for a little drive and didn't seem to slip in 4th. I'll just keep an eye on it over the next few weeks.
    VXR Torque of the Devil vxrtricky's Avatar
    17th April 2008
    5,176
    Sure it's not budget tyres on the front loosing grip? What make you have or how much life left?
    27th February 2015
    616
    Didn't notice that the traction light came on, I've got matador ultra sport hectorra 2's on with plenty of tread left. Never heard of the tyres but they were on the car when I bought it. Any views on them?
