Results 11 to 20 of 21
  1. #11
    26th April 2009
    22
    Quote Originally Posted by IanJ View Post
    No difference from memory the car just had the restrictor removed and some revision to the suspension etc
    http://media.vauxhall.co.uk/media/gb...frankfurt.html
    Restrictor?
  2. #12
    6th February 2008
    15,970
    Quote Originally Posted by glynmitch View Post
    Restrictor?
    Std car limited to 155 mph, super sport around 172mph
  3. #13
    VXR enough AJG's Avatar
    10th January 2010
    1,305
    In the real world the original 2010 model wasn't limited. I have had 169 MPH on the clock on German Autobahns and I'm not alone in that. I currently drive the 2014 face-lifted model but haven't had the chance yet to squeeze the firewall. I'm sure the maxxed out figure would be the same.
    That is a helluva speed for a car like this, and it was as solid as the Rock of Gibraltar when flat out.
  4. #14
    VXR enough JamesPD1975's Avatar
    19th March 2013
    1,149
    Quote Originally Posted by AJG View Post
    Yep I agree had 163 out of mine (tuned) and it had loads left didn't feel like I was near the limit had to lift off as traffic ahead! 😁😁😁😁
  5. #15
    VXRed Dows's Avatar
    22nd June 2013
    185
    I must say, I went from the Astra J to the siggy vxr and the brakes in comparison are terrible! Astra brembos were ace and I know the insignia's a heavy car n all but still shouldnt be that much diff! I had the callipers professionally sprayed and whilst they were off i put in new pads, braided lines and changed the brake fluid and they are still terrible! I asked the garage to bleed them again which they said they did but still no good! Is it just mine or are the insignia brakes generally pants?
  6. #16
    10th January 2010
    1,305
    Pants. But this is a two ton car
  7. #17
    19th March 2013
    1,149
    Default Differences between Supersport and older VXR Brembos
    Quote Originally Posted by Dows View Post
    Yep they are rubbish, discs and pads the weakest link....
  8. #18
    8th August 2013
    214
    I'm offering AP 6 pot kits for £1,800 for the Astra H currently. The price wouldn't be too different if someone wants to be a guinea pig?
    We haven't designed one for the Insignia yet as need a hub and wheel or a car to do the initial design work.
    Kits would include:
    AP forged 6 Pot calipers (CP9040)
    Disc size would depend on wheel size, but either 355 or 362 x 32mm
    2 x Custom bells
    2 x Custom brackets
    Braided lines
    DS2500 brake pads
    AP 5.1 brake fluid
  9. #19
    28th June 2015
    25
    is it not just the automatics that are restricted?
  10. #20
    17th September 2011
    950
    Has anyone tried upgraded discs and pads? I don't want to change the calipers and rotor diameter as this is an automatic MOT failure here in Denmark, but I can use upgraded discs - do they make a difference? The standard brakes feel sort of mushy when i push them to the limit - the car stops, but it doesn't feel entirely well mannered.
    BTW.: I had mine (2010 Sports Tourer) on a german autobahn last week (I have 50 miles to the nearest unrestricted autobahn ) and it did 270 kph on the speedo before I had to lift off - which registered as 254 kph on a GPS readout, so I am not too sure that Opel/VX have been completely honest with the restrictor. But then again, my parents 530d will do 270 on the speedo (not that I've tried of course) so I think they generally set the restrictor a bit on the high side to avoid germans complaining about their car only doing 245 kph - because if you live in germany, 250 kph on the autobahn is comparable to a human right!
    And as AJG wrote, the car was rock solid! I tried maxing out my Vectra and it was a scary experience - but the Siggy just takes it in its stride... No doubt that this car was designed with high speed cruising in mind!
