Results 1 to 7 of 7
Thread: De-cat Exhaust
    10th August 2014
    68
    Default De-cat Exhaust
    Hi guys, I take it that this exhaust is this one on ebay?
    Also would a full decat piper system effect anything like the turbo?
    Because of that then need a remap to adjust everything accordingly because of a different back pressure?
    If thats the case then does that mean that I would need to change to standard exhaust and take the map off just for the mot ?
    Or would the full system be fine without the need of a map?
    VXR Torque of the Devil iDan x's Avatar
    26th May 2010
    5,605
    Yeah that's the exhaust
    Without a map you may get the Emissions light to pop up.
    You will need a main cat on the exhaust to pass an mot
    M135i
    10th August 2014
    68
    So say I get that exhaust and get it mapped for performance and so the emission light doesn't show up.
    But then when the MOT is due what do you do then ? Because you can't just swap the exhaust to the standard one because the car is still tuned for the piper and not the standard? So would you have to go to the hassle of swapping the exhaust and then taking the map off just for the MOT?
    VXR enough Mikeyboi90's Avatar
    8th October 2011
    1,181
    Become friendly with an MOT tester or buy a sports cat
    26th May 2010
    5,605
    Quote Originally Posted by aidy_m View Post
    Will have to swap it over.
    If you keep the boost down and drive a short distance it shouldn't be a problem
    M135i
    15th May 2013
    17,889
    I really would never bother with decat. It's illegal and will void your insurance. Nothing wrong with a sports cat and the difference between sports cat and decat in terms of gains isn't enough to justify driving around illegally. Just my 2ps worth. Sports cat is deffo worth the extra wonga if buying a turbo back
    VXRed blooded Runesource's Avatar
    21st April 2014
    379
    I've been running a de-cat for about 7k miles; 6k with a remus 3 piece and 1k with my 3" cobra, no issues apart from eml light, sounds good.
