Results 1 to 7 of 7
    12th October 2014
    30
    Default Squeak from the clutch - Warranty
    just wondering if anyone has come across a problem like mine...
    A faint squeal as I pull away from stationary, just as the clutch starts to bite.
    Ive taken the car to Vauxhall 3 times now and each time they are saying they can't find the source of the noise even though they admit they can hear it. Now all of a sudden they think its a gearbox mount....which quite conveniently isn't covered by the warranty!
    Can anyone give me any advice about what this problem could actually be?
    VXRacing ahead
    26th February 2015
    586
    no idea what it is but mine does the same thing
    VXRed blooded Calbur789's Avatar
    29th December 2011
    404
    My neighbour had a squeak from the clutch pedal itself on her Corsa d (not a Vxr).
    Worth a check?
    12th October 2014
    30
    its definitely worth a check!
    16th July 2012
    73
    had this on mine, ended up bearing a clutch release bearing, it was like a 1/2 second squeal its only 1 bearing i just got mine done when they did the gearbox think a new bearing was about 95 quid.
    24th March 2015
    45
    mine does this too and I've been told its the clutch release bearing too. I think I'm going to book in for it doing soon, £95 isn't bad I guess
