Results 1 to 10 of 12
    VXRed durno69's Avatar
    20th October 2012
    81
    Default Burg boost gauge
    Bought a burg today and the gauge is reading -21 on idle, what would be up with it?
    7th February 2015
    32
    It's just vaccum it's normal altho mine sits closer to -30 sounds like you've got a vac leak or sticky vac solenoid. Hope this helps.
    20th October 2012
    81
    I think that's all been changed I'll have a look at the boost pipes
    24th April 2014
    70
    -21 & -30 psi??? Mine sits around 1 bar (14psi) vacuum, should I be worrying? Ha.
    VXRacing ahead BigDov's Avatar
    8th February 2014
    630
    The minus numbers should be around -24-25 for vacuum, if it's positive could be registering atmospheric pressure which is around 14 psi, otherwise if its positive or not negative then you have a vac leak as vacuum should be negative
    Sent from my HTC One_M8 using Tapatalk
    MK5 VXR - Piper Turbo Back - Bilstien B8 Shocks - Eibach Sportlines - Whiteline RARB - Forge Re-circ( Yellow spring) - CDti intake - Direct feed hose Kit - Forge FMIC - Forge Actuator( Red Spring) - ANSU Fuel Pump - RnD stage 3 remap.
    20th October 2012
    81
    Iv got a forge actuator would that have anything to do with it? Not sure if it's set up right
    20th October 2012
    81
    And when on boost the gauge is only reading 8 psi
    24th April 2014
    70
    8 psi is low to be boosting! Standard an astra should run around 14psi (1 bar)
    So from what you're saying BigDov, I have a vacuum leak somewhere as it should be twice as much as it is?
    8th February 2014
    630
    yup or yuor actuator isn't set up correctly or using the wrong spring( if its a forge unit)
    20th October 2012
    81
    Should I get the same psi in different gears? In 2nd it wasn't going above 4 psi but in
    Fourth I was getting 16 after playing about with the actuator
